4 Replies Latest reply on Mar 31, 2010 6:42 AM by gd380
    How to set aliasInkName to [No Alias]?
    gd380
      Greetings,
      So I have no problem using javascript to set an ink alias:
      myInk.aliasInkName = "myInkAliasColor";
      Works wonderfully.
      But how do I remove the alias?
      I've tried:
      myInk.aliasInkName = null;
      myInk.aliasInkName = "";
      myInk.aliasInkName = "[No Alias]";
      and several others.
      Help!
      Thank you!
      --Greg
        • 1. Re: How to set aliasInkName to [No Alias]?
          Shonkyin Level 3
          Hi Greg,
          Check this one
          //make and new spot colors "test1" and "test2" and run below code:
          app.activeDocument.inks[4].aliasInkName = "test2"//inks[0]-inks[3] for CMYK
          alert (app.activeDocument.inks[4].aliasInkName)
          app.activeDocument.inks[4].aliasInkName = "[No Alias]"
          Shonky
          • 2. Re: How to set aliasInkName to [No Alias]?
            gd380 Level 1
            Thanks, Shonky. That worked.
            I thought I tried that. Apparently I was mistaken.
            But I have another question: how do you test to see if a color is aliased?
            Neither of these seem to work:
                           if (tempInk.aliasInkName == "[No Alias]")
                                tempInk.aliasInkName = "test1";
                            else if (tempInk.aliasInkName == "[NoAlias]")
            Just curious - I don't actually need to do this and I can't think of a business case where I would need to.
            --Greg
            • 3. Re: How to set aliasInkName to [No Alias]?
              Shonkyin Level 3
              With below code you can check alias setting.
              var inklength = app.activeDocument.inks.length
              if (inklength>3)
              //starting from 5th color becuase you cannot set ink alias on first four
              for (a=4; a<inklength;a++)
              alert (app.activeDocument.inks[a].aliasInkName)
              Shonky
              • 4. Re: How to set aliasInkName to [No Alias]?
                gd380 Level 1
                Thanks, Shony.
                I was trying to get it to work in the context of an if statement, but testing for "[No Alias]" and others didn't seem to work.
                --Greg
