2 Replies Latest reply on Mar 26, 2010 9:03 AM by alcaponis
    DateField and phpMyAdmin problem
    alcaponis
      Hi, I have a dateField, var date1:Date and column in the phpMyAdmin table which is also date type.
      I dont find anywhere how to do this:
      When i choose in datefield a date it goes to a var date1 and then date1 goes to a phpMyAdmin.
      I need a date format like this : 2010-03-26.
      Maybe someone knows?
        • 1. Re: DateField and phpMyAdmin problem
          Matt Le Fevre Level 4
          <mx:DateField formatString="YYYY-MM-DD"/>
          will setup the datefields label in the correct format for you.
          how are you sending it to your database? PHP & a HTTPService?
          • 2. Re: DateField and phpMyAdmin problem
            alcaponis Level 1
                    import mx.events.DateChooserEvent;
                    [Bindable]
                    public var newGimimoData:Date;     //(date1)
            <mx:HTTPService id="newUser" url="php\newUser.php" method="POST" result="newUserResult(event)">
                <mx:request xmlns="">
                    <newuser>{newUsername}</newuser>
                    <newpassword>{newPassword}</newpassword>
            <newvardas>{newVardas}</newvardas>
            <newpavarde>{newPavarde}</newpavarde>
            <newklase>{newKlase}</newklase>
            <newgimimoData>{newGimimoData}</newgimimoData>                       // (date1)
                </mx:request>
                </mx:HTTPService>
            This line is in the function in which is newUser,send() and I know that it is wrong, but I dont know how to write it in flex:
            private function addNewUser():void{
            newGimimoData = newGimimoDataTxt.selectedItem.getDate();
            newUser.send();
            and this is all php file:
                $conn = mysql_connect($hostname_conn, $username_conn, $password_conn);
            mysql_select_db("socDB");
            //mysql_real_escape_string POST'ed data for security purposes
                $newuser = mysql_real_escape_string($_POST["newuser"]);
                $newpassword = mysql_real_escape_string($_POST["newpassword"]);
            $newvardas = mysql_real_escape_string($_POST["newvardas"]);
            $newpavarde = mysql_real_escape_string($_POST["newpavarde"]);
            $newklase = mysql_real_escape_string($_POST["newklase"]);
            $newgimimoData = mysql_real_escape_string($_POST["newgimimoData"]);
            $query = "SELECT * FROM vartotojas WHERE USERNAME = '$newuser'";
            $result = mysql_query($query);
            $logged = mysql_num_rows($result);
            if ($logged == 1)
            $log = false;
            else
            $log = true;
            if ($log == true)
            $sql = "INSERT INTO vartotojas (USERNAME, PASSWORD. VARDAS, PAVARDE, KLASE, GIMIMODATA) VALUES('$newuser','$newpassword','$newvardas','$newpavarde', '$newklase','$newgimimoData')";
            if (!mysql_query($sql, $conn))
            echo "<status>Sukurti nepavyko</status>";
            else
            echo "<status>Naujas vartotojas sukurtas!</status>";
            else
            echo "<status>Šis vartotojo vardas yra užimtas, bandykite kita!</status>";
