0 Replies Latest reply on Mar 26, 2010 8:39 AM by Kotesh365
    Unable to assign dataprovider to a ComboBox, which is an item renderer for AdvancedDataGridColumn
    Kotesh365
      I need to have a ComboBox as an ItemRenderer for AdvancedDataGridColumn.
      I could do it.
      For ComboBox I am setting : text="{data.underwriter}"
      I can see the ComboBox in AdvancedDataGrid with the value provided in 'text' property.
      My requirement:
      I need to have a list as a DataProvider for ComboBox and the selection should be 'text' property value('text' property value is in the list that I want to assign as DataProvider).
      Can someone review and help me out?
      Thanks in advance.
      -K
      Here is the custom ComboBox code:
      package actionScripts.controls
      import mx.controls.ComboBox;
      import mx.core.Application;
      public class UnderwriterComboBox extends ComboBox
        public var selected:String;
        //public var myDataProvider:Object;
        public function UnderwriterComboBox()
                  labelField = '@assetValue';
                  //this.selectedIndex = 0;
                  super.dataProvider = Application.application.underwriterList;
                  setIndex();
        private function setIndex():void{
                  if (this.dataProvider.length > 0)
                      for (var i:int; i<this.dataProvider.length; i++)
                       var strSel:String = this.dataProvider[i].@assetValue.toString();
                          if (strSel == selected)
                              this.selectedIndex = i;
                              break;
              public function set Selected(str:String):void{
                selected = str;
                setIndex();
              /* public function set MyDataProvider(dp:Object):void{
                  super.dataProvider = dp;
                  setIndex();
        /* override public function set dataProvider(dp:Object):void{
                  setIndex();
      Here is the MXML:
      <mx:AdvancedDataGridColumn
      id = "dUnderwriter" headerText="Underwriter" dataField="swatID"
      editable="
      false" width="80">
      <mx:itemRenderer>
      <mx:Component>
      <controls:UnderwriterComboBox
      tabEnabled="
      true" change="data.underwriter=selectedItem;"
      dataProvider="
      {parentDocument.underwriterList}" text="{data.underwriter}">
      <!--<controls:dataProvider>
      Selected="{data.underwriter}"
      labelField="assetValue"
      <mx:ArrayCollection source="{application.underwriterList}"/>
      </controls:dataProvider>-->
      </controls:UnderwriterComboBox>
      </mx:Component>
      </mx:itemRenderer>
      </mx:AdvancedDataGridColumn>
