1 Reply Latest reply on Mar 30, 2010 7:33 AM by olegkon
    Passing params in remoting
      I have an AIR2 app where I read/write Excel2007 files in DataGrid.
      Currently it works via WebService (server part in Java & POI framework).
      I am trying to rewrite it using Remoting.
      Few questions in that regard:
      1) Can I reuse the same Java part without changes (or minimal ones).
      For example, I have method:
      public String getExcelData(String fileName) ,
      which reads Excel file and returns me the contents as XML String,
      which I use as bound XMLListCollection for DataGrid.
      2) So how do I pass and receive parameters,
      input String fileName and
      output String  xmlData ?
      I have seen that example:
      <mx:Button label="Get Employee List" click="employeeRO.getList(dept.selectedItem.data);"/>
      But how to get the output param ?
      3) So it advisable or even possible to pass XML in String
      in Remoting ?
      Or do I have it via DTO (collection of CellData objects)?
      Please advise.
        • 1. Re: Passing params in remoting
          olegkon Level 1
          Few more questions about Remoting (new to me):
          4) If I create RemoteObject tag in MXML, I do not need to create a DTO in ActionScipt ?
          And DTO doesn't make sense, because I am only passing XML String, not some fancy structure, correct ?
          5) Anything new in Remoting in Flex4/AIR2 ?
