1 Reply Latest reply on Mar 31, 2010 11:53 AM by rita the reader
    Imported .swf files are truncated in Captivate
    sjgrodsky
      I create a file in Captivate, then publish it as a .swf file.
      I import it into my higher-level Captivate file and preview the entire project.
      The imported file plays all right initially, but sometimes it stops before the last slide is played.
      For example, I have a file that is 11:03 minutes long. It is composed of 99 slides.  It refuses to  play past the 71st slide.
      I've played around with the timing settings (Properties > Options tab). Setting  the "display for" setting to:
      • "rest of slide" sometimes works, but isn't reliable.
      • "duration of animation" doesn't work, though you'd think it would
      • "rest of project" is disastrous
      • "specific time" (and setting the time for longer than the embedded animation) also doesn't work
      Anyone else have this issue? I've tried to determine if there's a file size max, but sometimes larger files play successfully and smaller ones don't.
      TIA.
