0 Replies Latest reply on Mar 26, 2010 2:25 PM by kevinklin
    [svn:fx-trunk] 15077: Merge 15074 from 4.x to trunk.
    kevinklin Adobe Employee
      Revision: 15077
      Revision: 15077
      Author:   klin@adobe.com
      Date:     2010-03-26 14:24:44 -0700 (Fri, 26 Mar 2010)
      Log Message:
      Recommit fix for http://bugs.adobe.com/jira/browse/SDK-25919. For a non-mirroring application, we were calling invalidateLayoutDirection at startup even though we start out with the right layout. The fix is to default oldLayoutDirection to "ltr" so that we skip some of these calls at start up. We also need to make oldLayoutDirection mx_internal so that subclasses that don't call super.validateDisplayList() can update oldLayoutDirection correctly.
      QE notes: No
      Doc notes: No
      Bugs: SDK-25919
      Reviewer: Hans
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/ListBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
      Property Changed:
          flex/sdk/trunk/
