0 Replies Latest reply on Mar 26, 2010 2:48 PM by Carol L. Frampton
    [svn:fx-4.x] 15080: Fix FTE in UIFTETextField which occured if baseline getter was called before width or height were set and autoSize =TextFieldAutoSize.NONE.
    Carol L. Frampton Level 2
      Revision: 15080
      Revision: 15080
      Author:   cframpto@adobe.com
      Date:     2010-03-26 14:47:47 -0700 (Fri, 26 Mar 2010)
      Log Message:
      Fix FTE in UIFTETextField which occured if baseline getter was called before width or height were set and autoSize=TextFieldAutoSize.NONE.  In this case, createTextLinesFromTextBlock returned without creating any text lines because there wasn't any width.  FTETextField.getLineMetrics assumes there is at least one line and throws a range error if there isn't.  In this case, set autoSize to TextFieldAutoSize.LEFT, measure the text, and then restore the autoSize value.
      QE notes:
      Doc notes: None
      Bugs: SDK-26016
      Reviewed By: Jason
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-26016
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/spark/src/mx/core/UIFTETextField.as
