Revision: 15082
Revision: 15082
Author: klin@adobe.com
Date: 2010-03-26 15:06:02 -0700 (Fri, 26 Mar 2010)
Log Message:
Fix for http://bugs.adobe.com/jira/browse/SDK-25997. The knob in a dividedBox is incorrectly positioned. This is the result of a couple of things in BitmapAsset and SpriteAsset.
-Changed rotation setter to set super.rotation when not mirrored.
-width/height are now always positive regardless of whether scaleX/Y is negative.
-width/height getters now take the full transform into account. Basically, they return the bounding box size now.
-Also, BoxDivider sets the layoutDirection of its knob to null (inheriting) in order to be positioned correctly.
QE notes: No
Doc notes: No
Bugs: SDK-25997
Reviewer: Carol, Jason
Tests run: checkintests
Is noteworthy for integration: No
Ticket Links:
Modified Paths:
flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/containers/dividedBoxClasses/BoxDivider.as
flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/BitmapAsset.as
flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/SpriteAsset.as
