1 Reply Latest reply on Apr 20, 2010 2:05 PM by Tom Decaux
    video in Stratus 2 in Netgroup Pls help
    jananikrishna
      hello everybody
                               Please check my below code i cant get the other persons video .What is wrong with it? I am getting only my video.What should be done to get the other person's video.Pls help me.This is urgent
      Thanx
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" width="100%" height="100%" applicationComplete="OnApplicationComplete()">
          <mx:Script>
              <![CDATA[
                  private var netConnection:NetConnection = null;
                  private var netStream:NetStream = null;
                  private var netGroup:NetGroup = null;
                  private var video:Video = null;
                  private var sequenceNumber:uint = 0;
                  private var resizeTimer:Timer = null;
                  private const SERVER:String = "rtmfp://stratus.adobe.com/";
                  private const DEVKEY:String = "devkey";
                  [Bindable] private var connected:Boolean = false;
                  [Bindable] private var joinedGroup:Boolean = false;
                  private function OnApplicationComplete():void
                      //userName.text = "user " + int(Math.random() * 65536);
                     //groupName.text = "channel" + (int(Math.random() * 899) + 101);
                    groupName.text= "Group1"
                      resizeTimer = new Timer(2000.0);
                      resizeTimer.addEventListener(TimerEvent.TIMER, DoResizeVideo);
                      resizeTimer.start();
                  private function StatusMessage(msg:Object):void
                      statusLog.text += msg;
                      statusLog.verticalScrollPosition = statusLog.textHeight;
                      statusLog.validateNow();
                  private function NetStatusHandler(e:NetStatusEvent):void
                      StatusMessage(e.info.code);
                      switch(e.info.code)
                      case "NetConnection.Connect.Success":
                          OnConnect();
                          break;
                      case "NetConnection.Connect.Closed":
                      case "NetConnection.Connect.Failed":
                      case "NetConnection.Connect.Rejected":
                      case "NetConnection.Connect.AppShutdown":
                      case "NetConnection.Connect.InvalidApp":
                          OnDisconnect();
                          break;
                      case "NetStream.Connect.Success": // e.info.stream
                          OnNetStreamConnect();
                          break;
                      case "NetStream.Connect.Rejected": // e.info.stream
                      case "NetStream.Connect.Failed": // e.info.stream
                          DoDisconnect();
                          break;
                      case "NetGroup.Connect.Success": // e.info.group
                          OnNetGroupConnect();
                          break;
                      case "NetGroup.Connect.Rejected": // e.info.group
                      case "NetGroup.Connect.Failed": // e.info.group
                          DoDisconnect();
                          break;
                      case "NetGroup.Posting.Notify": // e.info.message, e.info.messageID
                          OnPosting(e.info.message);
                          break;
                      case "NetStream.MulticastStream.Reset":
                      case "NetStream.Buffer.Full":
                          DoResizeVideo();
                          break;
                      case "NetGroup.SendTo.Notify": // e.info.message, e.info.from, e.info.fromLocal
                      case "NetGroup.LocalCoverage.Notify": //
                      case "NetGroup.Neighbor.Connect": // e.info.neighbor
                      case "NetGroup.Neighbor.Disconnect": // e.info.neighbor
                      case "NetGroup.MulticastStream.PublishNotify": // e.info.name
                      case "NetGroup.MulticastStream.UnpublishNotify": // e.info.name
                      case "NetGroup.Replication.Fetch.SendNotify": // e.info.index
                      case "NetGroup.Replication.Fetch.Failed": // e.info.index
                      case "NetGroup.Replication.Fetch.Result": // e.info.index, e.info.object
                      case "NetGroup.Replication.Request": // e.info.index, e.info.requestID
                      default:
                          break;
                  private function DoConnect():void
                      StatusMessage("Connecting to \"" + SERVER + "\" ...\n");
                      netConnection = new NetConnection();
                      netConnection.addEventListener(NetStatusEvent.NET_STATUS, NetStatusHandler);
                      netConnection.connect(SERVER + DEVKEY);
                  private function OnConnect():void
                      var groupSpecifier:GroupSpecifier;
                      StatusMessage("\nConnected\n");
                      connected = true;
                      groupSpecifier = new GroupSpecifier("max2009lab/" + groupName.text);
                      groupSpecifier.multicastEnabled = true;
                      groupSpecifier.postingEnabled = true;
                      groupSpecifier.serverChannelEnabled = true;
                      netStream = new NetStream(netConnection, groupSpecifier.groupspecWithAuthorizations());
                      netStream.addEventListener(NetStatusEvent.NET_STATUS, NetStatusHandler);
                      netGroup = new NetGroup(netConnection, groupSpecifier.groupspecWithAuthorizations());
                      netGroup.addEventListener(NetStatusEvent.NET_STATUS, NetStatusHandler);
                      StatusMessage("Join \"" + groupSpecifier.groupspecWithAuthorizations() + "\"\n");
                  private function OnNetStreamConnect():void
                      netStream.client = this;
                      var mic:Microphone = Microphone.getMicrophone();
                      if(mic)
                          mic.codec = SoundCodec.SPEEX;
                          mic.setSilenceLevel(0);
                          netStream.attachAudio(mic);
                          StatusMessage("got microphone\n");
                      var camera:Camera = Camera.getCamera();
                      if(camera)
                          camera.setMode(320, 240, 10);
                          camera.setQuality(30000, 0);
                          camera.setKeyFrameInterval(15);
                          videoDisplay.attachCamera(camera);
                          videoDisplay.maintainAspectRatio = true;
                          netStream.attachCamera(camera);
                          StatusMessage("got camera\n");
                      netStream.publish("stream");
                  private function OnNetGroupConnect():void
                      joinedGroup = true;
                       senddata();
                  private function DoDisconnect():void
                      if(netConnection)
                          netConnection.close();
                      videoDisplay.attachCamera(null);
                  private function OnDisconnect():void
                      StatusMessage("Disconnected\n");
                      netConnection = null;
                      netStream = null;
                      netGroup = null;
                      connected = false;
                      joinedGroup = false;
                  private function ClearChatText():void
                      chatText.text = "";
                  private function DoPost():void
                      var message:Object = new Object;
                      message.user = userName.text;
                      message.text = chatText.text;
                      message.sequence = sequenceNumber++;
                      message.sender = netConnection.nearID;
                      netGroup.post(message);
                      StatusMessage(userName.text + "==> " + chatText.text + "\n");
                      chatText.callLater(ClearChatText);
                private function senddata():void
                       message.sender=netGroup.convertPeerIDToGroupAddress(netConnection.nearID);
                       receive(message);
                       message.user=userName.text;
                       message.text= statusLog.text;
                  private function receive(message:Object):void
                      write(message.user + ":" + chatText.text);
                  private function write(text:String):void
                      text=text +"\n";
                  private function OnPosting(message:Object):void
                      StatusMessage("<" + message.user + "> " + message.text + "\n");
                  private function DoResizeVideo(ignored:* = null):void
                      if(video)
                          if( (0 == video.videoHeight)
                           || (0 == video.videoWidth)
                              video.height = videoDisplay.height;
                              video.width = videoDisplay.width;
                              video.x = 0;
                              video.y = 0;
                          else
                              var videoAspect:Number = Number(video.videoWidth) / Number(video.videoHeight);
                              var displayAspect:Number = Number(videoDisplay.width) / Number(videoDisplay.height);
                              var adjustFactor:Number;
                              if(videoAspect >= displayAspect) // video is wider than display
                                  adjustFactor = Number(video.videoWidth) / Number(videoDisplay.width);
                                  video.height = int(Number(video.videoHeight) / adjustFactor);
                                  video.x = 0;
                                  video.y = int((videoDisplay.height - video.height) / 2);
                              else
                                  adjustFactor = Number(video.videoHeight) / Number(videoDisplay.height);
                                  video.width = int(Number(video.videoWidth) / adjustFactor);
                                  video.x = int((videoDisplay.width - video.width) / 2);
                                  video.y = 0;
                  public function onPlayStatus(info:Object):void {}
                  public function onMetaData(info:Object):void {}
                  public function onCuePoint(info:Object):void {}
                  public function onTextData(info:Object):void {}
                  public function ValidateConnectAllowed(isConnected:Boolean, groupNameText:String):Boolean
                      return (!isConnected) && (groupNameText.length > 0);
          </mx:Script>
          <mx:VBox top="10" right="10" left="10" bottom="10" verticalGap="6">
              <mx:HBox width="100%">
                  <mx:Text text="Group:"/>
                  <mx:TextInput id="groupName" width="100%" text="default" enabled="{!connected}"/>
                  <mx:Button label="Connect" click="DoConnect()" enabled="{ValidateConnectAllowed(connected, groupName.text)}" />
                  <mx:Button label="Disconnect" click="DoDisconnect()" enabled="{connected}" />
              </mx:HBox>
              <mx:VideoDisplay id="videoDisplay" width="320" height="240" resize="DoResizeVideo()"/>
              <mx:TextArea id="statusLog" width="100%" height="100%"/>
                  <mx:TextInput id="userName" width="160" />
                  <mx:TextInput id="chatText" width="100%" enabled="{joinedGroup}" enter="DoPost()"/>
              </mx:HBox>
          </mx:VBox>
      </mx:Application>
