8 Replies Latest reply on Apr 11, 2010 6:49 AM by arunkumard87
    Global Varible
    arunkumard87
      Hai all,
      I have a loign page, after user logged.i want to store all the logged in user details in one public arraycollection variable. i want to use the user details throw out the project. how to do that??
      Thanks in Advance..
      Regards,
      Arun Kumar
        • 1. Re: Global Varible
          kubens Level 2
          Main Application:
          <fx:Script>
          <![CDATA[
               [Bindable] public var user:ArrayCollection;
          </fx:Script>
          Module:
          <fx:Script>
          <![CDATA[
               trace(FlexGlobals.topLevelApplication.user['firstname'])
               trace(FlexGlobals.topLevelApplication.user['lastname'])
          </fx:Script>
          • 2. Re: Global Varible
            daslicht Level 2
            Cool,
            I didnt knew that it is possible like this neither , anytime I needed Globals I used a singleton for that.
            • 3. Re: Global Varible
              GordonSmith Level 4
              You could also declare your own MyGlobals class, declare 'user' as a static var in it, and access it as MyGlobals.user.
              Gordon Smith
              Adobe Flex SDK Team
              • 4. Re: Global Varible
                arunkumard87 Level 1
                Thanks for reply,
                     I am using Flex 3, how to assign value to the class (public) variable.
                Regards,
                Arun Kumar
                • 5. Re: Global Varible
                  kubens Level 2
                  GlobalVariables.as
                  package net.woocoom.basics
                      public class GlobalVariables
                          public var bar:String = 'foo'
                          public var foo:String = 'bar'
                          private static var _instance:GlobalVariables;
                          public function GlobalVariables(forcer: GlobalVariablesEnforcer){
                              if (_instance || !forcer) {
                                  throw new Error('Singleton Instantiation Error.');
                          public static function getInstance():GlobalVariables{
                              return _instance || new GlobalVariables (new GlobalVariablesEnforcer());
                  class GlobalVariablesEnforcer {
                  Inside you MXML
                  Alert.show(GlobalVariables.getInstance().bar,GlobalVariables.getInstance().foo)
                  • 6. Re: Global Variable
                    arunbiji
                    The answer is 'SharedObject'. PFB a sample way of using SO (Shared Object),
                    Create object --> public var <local_SO_name>:SharedObject = SharedObject.getLocal("<global_SO_name>" [, <path_name>]);
                    Setting data    --> <local_SO_name>.data.<data_name> = <data_value>;
                    Getting data    --> <local_object> = <local_SO_name>.data.<data_name>;
                    More details : http://livedocs.adobe.com/flex/3/langref/flash/net/SharedObject.html, http://livedocs.adobe.com/flex/3/html/help.html?content=lsos_3.html
                    • 7. Re: Global Variable
                      Thanks for reply,
                      Login page:
                      UserObj.SetDetails(ResArr[0]["id"],ResArr[0]["user_nm"]);
                      Class:
                      public function SetDetails(UserId:int,UserName:String):void
                                      So= SharedObject.getLocal("UserDtls");
                                      So.data.UserId=UserId;
                                      UID=UserId;
                                      So.data.UserName=UserName;
                                      So.flush(100);
                              public function GetDetails():int //:ArrayCollection
                                  So=SharedObject.getLocal("UserDtls");
                                  return So.data.UserId;
                      Thanks and regards,
                      Arun Kumar
                      • 8. Re: Global Variable
                        Thanks for reply,
                        I tried the below code. but its not working. could any one check and help me.
                        i checked in net . they are saying getLocal will work only when we use https.
                        Please correct the below code or tell some other method to do the same.
                        Login page:
                        Class:
                                        UID=UserId;
                                        So.flush(100);
                                    So=SharedObject.getLocal("UserDtls");\
                        Home page:
                        Alert.show(UserObj.GetDetails().toString());
                        <local:LgDtls id="UserObj" />
                        Thanks and Regards,
                        Arun Kumar
