3 Replies Latest reply on Apr 15, 2010 2:17 PM by olegkon
    Questions & Answer for Air 2.0 Beta 2x
    Jens Eckervogt Level 1
      Hello guys,
      I want to know about new version by Adobe Air 2.0.
      Question:
      #     1:
      Can i execute Air to binary like ( NativeProcess ) ?
      I have found url: http://www.adobe.com/devnet/air/flex/quickstart/interacting_with_native_process.html
      #     1,    a;
      Can i execute with 7zip or unzip binary. I found 7zip for supportted operating system. But it is different for 7z like:
      Windows:  7z ( It should without Miceosoft Installer *.msi )
      Linux:        p7z ( It should without debian or run script *.deb, *.run )
      Mac OS X: 7zX ( It should without disk image *.dmg )
      #     2:
      Can i use more binaries ( such compiled by Adobe Air 2.0 ) like multi application? If i want to 2 or more compiled air binary. If i use on Windows and you use another like Mac OS X or Linux than Air can to create more bionaries? How do i make sure with multi native processes? Sometime with command per adl.jar?
      #     3:
      Can Air ConfigApp for example write and load config.xml?
      I have searched with google. But it can not find I am still using with Flex Builder 3.5 ( SDK )
      #     4:
      Can Adobe Air mount with USB- , DVD- and CD-Device? like ImgBurn for Windows, Toaster for Mac OS X or K3b Image for Linux
      #     4,    a:
      Can it to mount with webspace or web disk image like Windows Live SkyDriver or Yahoo Fichlr Driver?
      #     5:
      Can i make an aero effect on Air Mainapp-Background like Windows Vista and 7?
      #     5,    a:
      If you use on Windows XP, Mac OS X or Linux with dpmapi by Windows Vista and 7 than it will default skin by Adobe Air. It is posible?
      Thanks best regards SnakeMedia
        • 1. Re: Questions & Answer for Air 2.0 Beta 2x
          Romil Mittal Adobe Employee
          1. Yes, AIR can run a native binary and you have the correct link to try it out. Let us know if you any queries in this area.
          Yes, you can run 'zip/unzip' binaries. Because they come in different forms (names) on different platforms, you will have handle them specific to each of them.
          2. Sorry, I didn't understand this. Can you please explain this more?
          3.Are you trying to build an AIR application that can read/write some configuration (from config.xml)? If yes, then the answer is 'yes - you can do that'.
          4. Are you trying to mount a drive using AIR? No, you cannot do that. AIR 2 can only detect a drive when it is mounted.
          5. Can you please explain this query again? Thanks.
          -romil
          • 2. Re: Questions & Answer for Air 2.0 Beta 2x
            Hello @Romil
            Thank you reply..
            If you do not understand?
            #     2: I mean about native process for multi application. like this:
            MyAppAir/. <- is My Application Air
            ./NativieApps/
            ./../Windows/ for Windows Vista and 7..
            ./../Mac/ for SnowLeopard and Leopard...
            When i use externed air applications like this
            I create frist support for NativeProcess.isSupport
            than i code with java binary for adl.jar :
            var file:File = File.applicationDirectory;
            file = file.resolvePath("NativeApps");
            if (Capabilities.os.toLowerCase().indexOf("win") > -1)
                file = file.resolvePath("Windows/adl.exe <../../DistApps/MyApp/myapp-app.xml>");
            } else if (Capabilities.os.toLowerCase().indexOf("mac") > -1)
                file = file.resolvePath("Mac/adl <../../DistApps/MyApp/myapp-app.xml>");
            } else if (Capabilities.os.toLowerCase().indexOf("linux") > -1)
                file = file.resolvePath("Linux/adl <../../DistApps/MyApp/myapp-app.xml>");
            For example. If you want to more than air applications inside one applications...
            For 5: okay i understand. it is crazy?
            ok i have problem with testting with nativeprocess error:
            <mx:WindowedApplication
            xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init()">
            <mx:Script>
            <![CDATA[
            // isSupport with calling binary
            private function init():void
            if(NativeProcess.isSupported){
            else {
            private function LaunchEditor():void
            appEditor();
            else {
            textReceived.text =
            "NativeProcess not supported. Sorry you must to wair for new version of Adobe Air! Thank you!";
            private function appEditor():void
            "NativeApps");
            "notepad.exe");
            "namo");
            "gedit");
            var nativeProcessStartupInfo:NativeProcessStartupInfo = new
            NativeProcessStartupInfo();
            nativeProcessStartupInfo.executable = file;
            var process:NativeProcess = new NativeProcess();
            </mx:Script>
            <mx:Button label="Start Editor" left="10" top="10" click="LaunchEditor()"/>
            <mx:TextArea left="10" top="40" right="10" bottom="10" id="textReceived" text="Please start your Editor from Windows or from mac" editable="false" wordWrap="true"/>
            </mx:WindowedApplication>
            I have problem with native shell like default with windows binary notepad.exe from C:\Windows\notepad.exe I can not start becasue it gave error!
            ArgumentError: Error #3214: NativeProcessStartupInfo.executable does not specify a valid executable file.
            at Error$/throwError()
            at flash.desktop::NativeProcessStartupInfo/set executable()
            at smConfig/appEditor()[F:\Flex-Src\smConfig\src\smConfig.mxml:40]
            at smConfig/LaunchEditor()[F:\Flex-Src\smConfig\src\smConfig.mxml:18]
            at smConfig/___smConfig_Button1_click()[F:\Flex-Src\smConfig\src\smConfig.mxml:46]
            What does it happen? If Adobe Air 2.0 Beta 2 can not work? Or is it not allowed??
            best regards, SnakeMedia
            • 3. Re: Questions & Answer for Air 2.0 Beta 2x
              olegkon Level 1
              SnakeMedia,
              That error 3214 most likely means that you are not pointing to the JDK dir correctly.
              I am often getting it when specified JDK dir (JAVA_HOME) doesn't exist on PC where you install your AIR2 app.
              My app is based on that embedded Tomcat app [needs JDK to start/stop Tomcat]:
              http://coenraets.org/blog/2009/12/embedding-tomcat-and-blazeds-in-an-air-2-0-application/
              Hope that helps,
              Oleg.
