9 Replies Latest reply on Sep 14, 2007 8:24 PM by Newsgroup_User
    datagrid even
    Level 7
      Hi All,
      How can I fire an event in my datagrid?
      Or maybe create my own event so I can use it anywhere.
      Any samples or links?
      JFB
        • 2. Re: datagrid even
          Level 7
          Thanks...
          I try this but doesn't work for me. Maybe I have to approach my problem in
          different way.
          I have a datagrid to calculate amounts, also inside the datagrid I have a
          comboBox that contains my rate types.
          When I create a new rows no problem everything works, I defined a function
          in my datagrid "change" method where I do the calculations after I setup the
          type of rate manually. After that I save this on my database.
          Now if I get the record for update, I'm able to get the info into the
          datagrid but the calculations doesn't fire automatic.
          How can I fire "change" method?
          Also any idea how can I set the value of the comboBox?
          Since I'm creating a comboBox everytime I create a row, it's not a way to
          reach the comboBox from outside...
          Tks
          JFB
          "ProfessorC" <webforumsuser@macromedia.com> wrote in message
          news:fc77vu$ori$1@forums.macromedia.com...
          > You would create your own class that extends DataGrid, and add your own
          > events.
          > See:
          > http://flexblog.faratasystems.com/?p=170
          > http://www.adobe.com/devnet/flex/quickstart/building_components_using_code_behin
          > d/
          > http://blog.paranoidferret.com/index.php/2007/07/27/flex-friday-feature-datagrid
          > -component/
          > http://blog.olivermerk.ca/index.cfm/2007/5/23/Flex-Custom-Events
          • 3. Re: datagrid even
            ProfessorC Level 1
            Can we see your code?
            Are you using a custom cell editor for the combobox?
            If you are, I don't believe the change event fires, as you said. But the DataGrid has a series of non-inherited events - itemEditBegin, itemEdtiEnd, itemEditBeginning, itemEditFocusIn and itemEditFocusOut - that you can hook a hander onto. The itemEditEnd should do exactly what you're looking to do. Hook onto that, rather than (or in addition to) the change event for all your processing when a cell's value has been changed via a custom cell editor.
            Check out "Working with Item Editors" in LiveDocs for more info and some great examples http://www.adobe.com/livedocs/flex/201/html/celleditor_073_01.html
            • 4. Re: datagrid even
              Level 7
              Thanks for you reply and help.
              Let me put some code here (I have a long form)
              I'm new in flex and I will check the documentation that you mention but if
              you can explain me I will really help with my time.
              Rgds
              JFB
              public function calculateRateTotal(event:Event):void{
              Here I do all calculations...
              public function getEstimateQtyRO_Handler(event:ResultEvent):void{
              acEstimateQty = ArrayCollection(event.result);
              for(var i:Number=0; i< acEstimateQty.length; i++) {
              //Here I build my Array collection
              acPrice.addItem({qty:acEstimateQty .estimateQty,
              perpiece:acEstimateQty
              .estimatePerPiece,
              setupfee:acEstimateQty .estimateSetupFee});
              //Here I need to fire the event
              //Also need to find the way to update rate_cd.selectedIndex
              price_dg.dataProvider = acPrice;
              <mx:DataGrid id="price_dg" change="calculateRateTotal(event)" x="10" y="28"
              width="590" height="147" editable="true">
              <mx:columns>
              <mx:DataGridColumn headerText="Quantity" dataField="qty"/>
              <mx:DataGridColumn headerText="Rate Type" dataField="rateid"
              editable="false" width="120">
              <mx:itemRenderer>
              <mx:Component>
              <mx:VBox>
              <mx:ComboBox id="rate_cb" dataProvider="{outerDocument.acRate}"
              labelField="label" change="outerDocument.setRate(rate_cb)" width="120"/>
              </mx:VBox>
              </mx:Component>
              </mx:itemRenderer>
              </mx:DataGridColumn>
              <mx:DataGridColumn headerText="per Piece" dataField="perpiece"
              editable="false"/>
              <mx:DataGridColumn headerText="per 1000" dataField="per1000"
              editable="false" labelFunction="formatNumber"/>
              <mx:DataGridColumn headerText="Setup Fee" dataField="setupfee" />
              <mx:DataGridColumn headerText="Total" dataField="total"
              editable="false" />
              </mx:columns>
              </mx:DataGrid>
              news:fc9c39$a5d$1@forums.macromedia.com...
              > itemEdtiEnd,
              > hook a
              > Hook
              > great
              > examples
              • 5. Re: datagrid even
                ProfessorC Level 1
                Basically... instead of
                <mx:DataGrid ... change="calculateRateTotal(event)" ...>
                make it
                <mx:DataGrid ... itemEditEnd="calculateRateTotal(event)" ...>
                then, in calculateRateTotal, check that it's a field/column that you care about
                public function calculateRateTotal(event:DataGridEvent):void {
                if(event.dataField == "rateid") {
                var chosenItem:Object= ComboBox(event.currentTarget.itemEditorInstance).selectedItem;
                var chosenRateId:int=chosenItem.rateid;
                // do whatever calculations you need to, using chosenRateId as the rate the user chose in the combobox, or whatever other fields you need to use
                As per the documentation, you might also need to check that the reason that the item editor is closing is not because the user simply cancelled out of it
                if (event.reason <> DataGridEventReason.CANCELLED)
                I would also remove the change event handler on the combobox itself.
                • 6. Re: datagrid even
                  Level 7
                  I got the idea.. tks for you help.
                  The problem now is... after I setup manually the rateID I go to the database
                  and find the correct % to do the calculation, I have to do this because it's
                  base on qty and rateid together.
                  When the results come back from the Database I fire the function to
                  calculate the amounts.
                  Now I got error there...
                  public function getRateTableRO_Handler(event:ResultEvent):void
                  acRateTable = ArrayCollection(event.result);
                  calculateRateTotal(event); // Here is the error now
                  How can I fixed this?
                  Maybe other way to do this?
                  Rgds
                  JFB
                  news:fc9hji$gc5$1@forums.macromedia.com...
                  > make it
                  > about
                  > the
                  > use
                  > that
                  > it
                  • 7. Re: datagrid even
                    Level 7
                    I got more careful and looks like the itemEditEnd doesn't fire when I change
                    anything on my comboBox.
                    What can I do?
                    Tks
                    JFB
                    > make it
                    > about
                    > the
                    > use
                    > that
                    > it
                    • 8. Re: datagrid even
                      Level 7
                      I create my comboBox in a separate component mxml now looks like it fire if
                      I click somewhere else but I'm getting an error in this line
                      var chosenItem:Object =
                      Error: cannot convert components::itemComboBoxRate@c51d479 to
                      mx.controls.ComboBox.
                      Please help
                      Rgds
                      JFB
                      > make it
                      > about
                      > the
                      > use
                      > that
                      > it
                      • 9. Re: datagrid even
                        Level 7
                        I fixed the error:
                        ComboBox(event.currentTarget.itemEditorInstance.rate_cb).selectedItem;
                        Now I got an error after click out of the datagrid.
                        Error #1069: Property selectedItem not found on NewEstimate_inlineComponent1
                        and there is no default value.
                        But If I fill the ArrayCollection from my database and set the datagrid
                        dataprovider with this array, the itemEditEnd doesn't fire... so I still
                        stack here.
                        Any other ideas?
                        Tks
                        JFB
                        > make it
                        > about
                        > the
                        > use
                        > that
                        > it
