14 Replies Latest reply on Sep 20, 2007 8:03 AM by Newsgroup_User
    CSS styles show in Safari, not Firefox
    warrenP Level 1
      If you go to http://www.noematiks.com on a Mac, the BOLD styles show in Safari but not in Firefox. Not sure about a Windows machine yet.
      The domain nameservers were changed about 32 hours ago and maybe propagation is causing this issue (thats what my host said).
      Any ideas?
        • 1. Re: CSS styles show in Safari, not Firefox
          Level 7
          Looks OK in Win FF2.0.
          --Nancy O.
          Alt-Web Design & Publishing
          www.alt-web.com
          "warrenP" <webforumsuser@macromedia.com> wrote in message
          news:fccbi1$o89$1@forums.macromedia.com...
          Safari
          propagation
          > Any ideas?
          • 2. Re: CSS styles show in Safari, not Firefox
            warrenP Level 1
            Thanks Nancy.
            FF (or FX as they like to abbreviate it) on Mac is not working. This is quite strange; never seen anything like it.
            • 3. Re: CSS styles show in Safari, not Firefox
              Level 7
              > Safari
              > propagation
              That's unlikely.
              Is there some reason you're using a CSS class applied with a <span> to make
              those phrases bold? Why not just use <strong>? That would be more correct
              semantically (since those seems to be phrases that you want to emphasize
              strongly), and almost all browsers will display them in boldface.
              Patty Ayers | Adobe Community Expert
              www.WebDevBiz.com
              Free Articles on the Business of Web Development
              Web Design Contract, Estimate Request Form, Estimate Worksheet
              • 4. Re: CSS styles show in Safari, not Firefox
                warrenP Level 1
                That's an idea, to see if it fixes the problem. I guess I just got used to using the SPAN code that I've used over and over without a problem. Thank You.
                • 5. Re: CSS styles show in Safari, not Firefox
                  Level 7
                  news:fccmsp$68c$1@forums.macromedia.com...
                  > You.
                  It should work everywhere, and is better code. Let us know how you do.
                  www.WebDevBiz.com
                  • 6. Re: CSS styles show in Safari, not Firefox
                    warrenP Level 1
                    I went with the <strong> code. All is good, but it doesn't clarify why the <span> code would not work like it has many times before. Another strang'ity of technology.
                    • 7. Re: CSS styles show in Safari, not Firefox
                      Level 7
                      news:fce6uv$rbh$1@forums.macromedia.com...
                      >I went with the code. All is good, but it doesn't clarify why the
                      Okay, but you should use <strong></strong>, if you want to write good valid
                      code.
                      I don't know why the <span> code didn't work, but because it's less than
                      correct, it doesn't seem worthwhile to figure out! :-)
                      www.WebDevBiz.com
                      • 8. Re: CSS styles show in Safari, not Firefox
                        Level 7
                        On Fri, 14 Sep 2007 11:31:28 -0400, "P@tty Ayers ~ACE"
                        >code.
                        I see nothing invalid about applying bold somehow other than *strong*.
                        One long time customer specifically wants some things as images
                        WITHOUT alt text as he doesn't want that text to apply to search
                        engines. Someone else may want to style text bold or italic, but does
                        not want the semantics applied. That is perfectly okay.
                        >www.WebDevBiz.com
                        • 9. Re: CSS styles show in Safari, not Firefox
                          Level 7
                          "Mister Mustard" <mustard@hotdog.com> wrote in message
                          news:2eule318me8p6s2oh1b10l5vjnfq21c1a1@4ax.com...
                          >>valid
                          >>code.
                          Of course it's OK - it's OK to write any kind of code you want. But if you
                          want clean, semantically meaningful code, it just makes more sense to mark
                          up words that are meant to be emphasized strongly as <strong> or <em>
                          rather than as <span>. <span> doesn't mean anything, while <strong> does.
                          HTML is a "markup language", meant to "mark up" text in such a way that
                          various user agents can display it in meaningful ways. Using lots of
                          meaningless tags is never as good code as using semantically meaningful
                          tags. Once you used the semantically meaningful tag, you can always
                          determine how it's displayed by applying CSS. Conveniently enough, just
                          about all browsers display <strong> in boldface, so there's usually no need
                          to apply CSS to is.
                          It's one thing if you just don't care about clean code - then it's all a
                          moot point. But it's funny that people do that - replace <em> and <strong>
                          with spans which they then style as italic and bold - because they think
                          it's *better* code because they're using CSS. That's completely backwards.
                          Having said that, I truly don't care what kind of code you or the original
                          poster write. Do whatever you want and have fun, and/or get the job done.
                          I'm all for that. I was just commenting on what semantically correct HTML
                          is.
                          www.WebDevBiz.com
                          • 10. Re: CSS styles show in Safari, not Firefox
                            Level 7
                            On Fri, 14 Sep 2007 20:34:18 -0400, "P@tty Ayers ~ACE"
                            You are presuming someone wants the semantics and I demonstrated that
                            this is sometimes not the case. I'm pretty sure I am every bit as much
                            in favor of them as are you, but there are times when you not want to
                            use them.
                            >to apply CSS to is.
                            >moot point.
                            Oh, so anyone who isn't always using semantic markup writes poor code.
                            No kidding.
                            >is.
                            >www.WebDevBiz.com
                            • 11. Re: CSS styles show in Safari, not Firefox
                              Level 7
                              news:jhfme35g4abgnbiaavslj45hhukiujqiog@4ax.com...
                              > use them.
                              No, actually, I wrote that of course it's fine to write it any way that
                              works for you. :-)
                              www.WebDevBiz.com
                              • 12. Re: CSS styles show in Safari, not Firefox
                                Level 7
                                On Fri, 14 Sep 2007 21:09:27 -0500, Mister Mustard <mustard@hotdog.com>
                                Actually, you didn't really demonstrate anything. You said that you had
                                a customer who didn't want alt text on images. That's not really the
                                same thing.
                                In any case, the "proper" way to have done that would have been to
                                assign empty strings to the alt attribute (alt="") to prevent screen
                                readers from reading the image file name as some will do in the absence
                                of alt text. Imagine some poor guy listening to his screen reader
                                working it's way through one of those awful Fireworks layouts and
                                listening to spacer.gif 317 times. ;-)
                                The point with semantics is that, when you change the appearance of
                                something, there is almost always a reason for doing so. It's normally
                                because you want to draw attention to it. If that's the case, there's
                                usually a semantic mark-up that would be more appropriate.
                                Note that almost all rules have exceptions. I wouldn't suggest that
                                there is never a reason to use a <span>, but those situations would be
                                pretty rare.
                                • 13. Re: CSS styles show in Safari, not Firefox
                                  Level 7
                                  On Sat, 15 Sep 2007 10:58:03 -0500, Gary White
                                  >same thing.
                                  I believe I demonstrated that sometimes we may wish to show something
                                  visually, but not semantically.
                                  I never use FW layouts and the empty alt is exactly what I used.
                                  Right, but note that you said, "almost always". I was talking about
                                  the times when this isn't the case.
                                  >pretty rare.
                                  • 14. Re: CSS styles show in Safari, not Firefox
                                    Level 7
                                    On Thu, 20 Sep 2007 08:02:17 -0500, Mister Mustard <mustard@hotdog.com>
                                    >>same thing.
                                    No. You really didn't, but I suppose we'll just have to agree to
                                    disagree.
