0 Replies Latest reply on Mar 28, 2010 7:10 AM by kubens
    How to deploy on different environments when using DataServices
    kubens
      I asked this question in the Flash Builder 4 and Flex 4 Labs Archive Forum some weeks ago. But the forum was closed in the meantime so that it is not possible to post further comments there. Therefore I post my solution here, may it is interesting for other people too:
      1. Compiler Argument
      I added a compiler argument for the project: -define+=CONFIG::environment,'dev'
      2. Global Variables
      I defined a global variable in the main application:
           public var BASEURL:String;
      I added in the main application inside the applicationComplete event following logic:
           switch (CONFIG::environment)
           case 'prod':
             BASEURL = 'http://www.woocoom.net/db/';
             break;
           case 'dev':
             BASEURL = 'http://www.woocoom.net.localhost:7070/db/';
             break;
      3. Generated Sub-Class of Service
      I set the baseURL inside the constructor based on the global variable.
           package net.woocoom.modules.newsstatus.services
             import mx.core.FlexGlobals;
             public class NewsStatusService extends _Super_NewsStatusService
               public function NewsStatusService():void
                 super();
                 _serviceControl.baseURL = FlexGlobals.topLevelApplication['BASEURL'];
      If I want to switch the environments then I just must change the compiler argument and recompile the project.
      Cheers
      Wolfgang
