4 Replies Latest reply on Mar 29, 2010 9:11 AM by Loic.Aigon
    Is a File writable ?
    Loic.Aigon Adobe Community Professional
      I want to write a File on a local machine. I would like to check that the file is not open yet.
      Is that possible ?
      TIA Loic
        • 1. Re: Is a File writable ?
          rkewlani Level 2
          You might want to put the file.opene call in a try/catch block & take corrective actions in the catch block.
          try{
          file.open(...)
          catch(e:Error)
          • 2. Re: Is a File writable ?
            Thanks a lot for your answer.
            File.open() seems to return true whatever the context :-S (File open or not).
            The file is a PDF open in Acrobat BTW.
            Thanks again anyway.
            Loic
            • 3. Re: Is a File writable ?
              rkewlani Level 2
              I tried the piece of code given below & it worked for me. Even if the file is not opened, it doesn't make any chages to it (confirmed the checksum & it's the same)
              var file:File = File.desktopDirectory.resolvePath("123.pdf");
              var fileStream:FileStream = new FileStream();
              try{
                                          fileStream.open(file, FileMode.APPEND);
                                          fileStream.writeUTFBytes("");
                                          fileStream.close();
                  catch(e:Error)
                                          trace(e.message);
              • 4. Re: Is a File writable ?
                Hi and thanks for the time you spent on that topic.
                You were right :-)
                Loic
