4 Replies Latest reply on Mar 29, 2010 9:30 PM by real_ideveloper
    Image width on adding
    real_ideveloper Level 1
      Hi all.
      I would like to know how i can figure out the width of an image after adding it to the canvas.
      I was trying to call the width getter method, but it returned 0.
      I could get width with the MOUSE.CLICK - Event, but i need it immediately after adding to the canvas.
      Could somebody give me an advice to solve this problem?
        • 1. Re: Image width on adding
          Peter deHaan Level 4
          If you're loading the image dynamically, you may need to wait until the complete event handler before you can access the image's dimensions.
          Peter
          • 2. Re: Image width on adding
            Hi Peter.
            Thank you for your fast answer.
            When I wait until the creation is complete and afterwards i am trying to get the width parameters with EVENT.COMPLETE handler then i get the same value of 0.
            Or do i something wrong?
            Could somebody post me an example???
            • 3. Re: Image width on adding
              Vikash.kumar29 Level 3
              Use following code, may be this is what you are looking for:
              <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
                  <mx:Script>
                      <![CDATA[
                          private function onImageLoadHandler(event:Event):void
                              var bmp:Bitmap = event.target.content as Bitmap;
                              trace("Height :: " + bmp.height);
                              trace("Width  :: " + bmp.width)
                  </mx:Script>
                  <mx:Image source="image.png" complete="onImageLoadHandler(event)">
                  </mx:Image>
              </mx:Application>
              Cheers
              -Vikash
              • 4. Re: Image width on adding
                Vikash, it was the solution.
                Thank you!!!!!!!!
                P.S.:
                After I have read your codesnippet, I've found that the event.targent.contentWidth does the same
