2 Replies Latest reply on Apr 6, 2010 11:22 AM by EliezerReis
    Type of PageItem element
    EliezerReis Level 1
      On my document I have for example 20 page itens, some of them could be ovals, textframes, graphic and so on. How can I check the type of page item?
      For example:
      for (int i=0; i< document.countPageItems();i++) {
           PageItem item = document.getAllChildPageItems()[i];
           TextFrame frame = TextFrameHelper.narrow(item); //Here, how can i know the exact type of my item?
        • 1. Re: Type of PageItem element
          Bart Devos Level 1
          pi.getObjectSpecifier() where "pi" is the pageitem object gives you a specifier string. With some regex magic, you can strip-out the appropriate objecttype.
          Hope this helps!
          Bart Devos
          • 2. Re: Type of PageItem element
            EliezerReis Level 1
            It works, but  I discovered that I can use the method _is_a. Each helper (ImageHelper, TextFrameHelper and etc) has a static method id() so, I can do something like this:
            for (Graphic graph : page.getAllGraphics()) {
             //check if graphic is a Image
             if (graph._is_a(ImageHelper.id())) {
             //check if graphic is a Polygon
             if (graph._is_a(PolygonHelper.id())) {
            Thanks a lot
