2 Replies Latest reply on Mar 30, 2010 4:48 PM by mirazero
    'flex.messaging.services.HTTPProxyService' error
    mirazero
      I have met below error in using lcds 2.5.1....
      how can i fix this error ?
      i have already update commons-http.jar file. but same....
      thanks,
      flex.messaging.config.ConfigurationException: Unable to create service 'flex.messaging.services.HTTPProxyService' for 'proxy-service' due to the following error: org/apache/commons/httpclient/HostConfiguration.ANY_HOST_CONFIGURATION.
                  at flex.messaging.config.MessagingConfiguration.createServices(MessagingConfiguration.java:2 02)
                  at flex.messaging.config.MessagingConfiguration.configureBroker(MessagingConfiguration.java: 84)
                  at flex.messaging.MessageBrokerServlet.init(MessageBrokerServlet.java:105)
                  at jeus.servlet.loader.ServletReloader.doInitInstance(ServletReloader.java:70)
                  at jeus.servlet.loader.PrivateReloader.initInstance(PrivateReloader.java:155)
                  at jeus.servlet.loader.PrivateReloader.getInstance(PrivateReloader.java:114)
                  at jeus.servlet.loader.ServletReloader.getServlet(ServletReloader.java:49)
                  at jeus.servlet.engine.ServletWrapper.loadOnStartup(ServletWrapper.java:100)
                  at jeus.servlet.engine.ServletManager.doPreloadServlets(ServletManager.java:428)
                  at jeus.servlet.engine.ServletManager.preloadServlets(ServletManager.java:391)
                  at jeus.servlet.engine.Context.preloadServlets(Context.java:1129)
                  at jeus.servlet.engine.Context.doStart(Context.java:1018)
                  at jeus.servlet.engine.Context.execStart(Context.java:835)
                  at jeus.management.j2ee.WebModule.preStart(WebModule.java:396)
                  at jeus.management.j2ee.J2EEManagedObject.start(J2EEManagedObject.java:860)
                  at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:79)
        • 1. Re: 'flex.messaging.services.HTTPProxyService' error
          Steve L Walker Level 5
          Do you have the proxy-service defined in the services-config.xml?
          Steve
          • 2. Re: 'flex.messaging.services.HTTPProxyService' error
            mirazero Level 1
            here is our configuration...
            Service-Config.xml
            <?xml version="1.0" encoding="UTF-8"?>
            <services-config>
            <factories>
              <factory id="springServiceFactory" class="das.fw.flex.SpringServiceFactory" />
            </factories>
                <services>
                    <service-include file-path="remoting-config.xml" />
                    <service-include file-path="proxy-config.xml" />
                    <service-include file-path="messaging-config.xml" />
                    <service-include file-path="data-management-config.xml" />
                </services>
                <security>
                    <login-command class="flex.messaging.security.JRunLoginCommand" server="JRun"/>
                    <!-- Uncomment the correct app server
                    <login-command class="flex.messaging.security.TomcatLoginCommand" server="Tomcat"/>
                    <login-command class="flex.messaging.security.WeblogicLoginCommand" server="Weblogic"/>
                    <login-command class="flex.messaging.security.WebSphereLoginCommand" server="WebSphere"/>
                    <security-constraint id="basic-read-access">
                        <auth-method>Basic</auth-method>
                        <roles>
                            <role>guests</role>
                            <role>accountants</role>
                            <role>employees</role>
                            <role>managers</role>
                        </roles>
                    </security-constraint>
                </security>
                <channels>
                    <channel-definition id="my-amf" class="mx.messaging.channels.AMFChannel">
                        <endpoint uri="http://{server.name}:{server.port}/{context.root}/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
                        <properties>
                            <polling-enabled>false</polling-enabled>
                        </properties>
                    </channel-definition>
                    <channel-definition id="my-secure-amf" class="mx.messaging.channels.SecureAMFChannel">
                        <endpoint uri="https://{server.name}:9100/{context.root}/messagebroker/amfsecure" class="flex.messaging.endpoints.SecureAMFEndpoint"/>
                    <channel-definition id="my-polling-amf" class="mx.messaging.channels.AMFChannel">
                        <endpoint uri="http://{server.name}:{server.port}/{context.root}/messagebroker/amfpolling" class="flex.messaging.endpoints.AMFEndpoint"/>
                        <properties>
                            <polling-enabled>true</polling-enabled>
                            <polling-interval-seconds>8</polling-interval-seconds>
                        </properties>
                    <channel-definition id="my-rtmp" class="mx.messaging.channels.NetConnectionChannel">
                        <endpoint uri="rtmp://{server.name}:2038" class="flex.messaging.endpoints.RTMPEndpoint"/>
                        <properties>
              <block-rtmpt-polling-clients>true</block-rtmpt-polling-clients>
                            <idle-timeout-minutes>60</idle-timeout-minutes>
                            <!--<client-to-server-maxbps>100K</client-to-server-maxbps>
                            <server-to-client-maxbps>100K</server-to-client-maxbps>-->
                            <!-- for deployment on WebSphere, must be mapped to a WorkManager available in the web application's jndi context.
                            <websphere-workmanager-jndi-name>java:comp/env/wm/MessagingWorkManager</websphere-workman ager-jndi-name>
                        </properties>
                    <channel-definition id="my-http" class="mx.messaging.channels.HTTPChannel">
                        <endpoint uri="http://{server.name}:{server.port}/{context.root}/messagebroker/http" class="flex.messaging.endpoints.HTTPEndpoint"/>
                    <channel-definition id="my-secure-http" class="mx.messaging.channels.SecureHTTPChannel">
                        <endpoint uri="https://{server.name}:9100/{context.root}/messagebroker/httpsecure" class="flex.messaging.endpoints.SecureHTTPEndpoint"/>
                </channels>
                <logging>
                    <target class="flex.messaging.log.ConsoleTarget" level="Error">
                        <properties>
                            <prefix>[Flex] </prefix>
                            <includeDate>false</includeDate>
                            <includeTime>false</includeTime>
                            <includeLevel>false</includeLevel>
                            <includeCategory>false</includeCategory>
                        </properties>
                        <filters>
                            <pattern>Endpoint.*</pattern>
                            <pattern>Service.*</pattern>
                            <pattern>Configuration</pattern>
                        </filters>
                    </target>
                </logging>
                <system>
                    <redeploy>
                        <enabled>true</enabled>
                        <watch-interval>20</watch-interval>
                        <watch-file>{context.root}/WEB-INF/flex/services-config.xml</watch-file>
                        <watch-file>{context.root}/WEB-INF/flex/proxy-config.xml</watch-file>
                        <watch-file>{context.root}/WEB-INF/flex/remoting-config.xml</watch-file>
                        <watch-file>{context.root}/WEB-INF/flex/messaging-config.xml</watch-file>
                        <watch-file>{context.root}/WEB-INF/flex/data-management-config.xml</watch-file>
                        <touch-file>{context.root}/WEB-INF/web.xml</touch-file>
                    </redeploy>
                </system>
            </services-config>
            Proxy-Config.xml
            <service id="proxy-service"
                class="flex.messaging.services.HTTPProxyService"
                messageTypes="flex.messaging.messages.HTTPMessage,flex.messaging.messages.SOAPMessage">
                <properties>
                    <connection-manager>
                        <max-total-connections>100</max-total-connections>
                        <default-max-connections-per-host>2</default-max-connections-per-host>
                    </connection-manager>
                    <allow-lax-ssl>true</allow-lax-ssl>
                </properties>
                <adapters>
                    <adapter-definition id="http-proxy" class="flex.messaging.services.http.HTTPProxyAdapter" default="true"/>
                    <adapter-definition id="soap-proxy" class="flex.messaging.services.http.SOAPProxyAdapter"/>
                </adapters>
                <default-channels>
                    <channel ref="my-http"/>
                    <channel ref="my-amf"/>
                </default-channels>
                <destination id="DefaultHTTP">
                </destination>
            </service>
