15 Replies Latest reply on Apr 15, 2010 11:24 PM by Rahul karn1
    Changing header and footer in massive projects
    Rahul karn1 Level 1
      Hi all,
      I am working with RH8 but i have to work on the project which is created in RH5.0.2.It contain total of 249 project and one project in which all the projects are merged.Worst part is that in the project, master page is only used in the parent project.
      My problem is:
      1. I have to update headers and footers,do i need to update in all the 249 projects separately and then merge in the final (parent) project or there is any other way out?
      2. If i make changes in any of the project,do i need to remerge it again? what should i care about while doing this?
      3. Do we need to regenerate the all chm files again or the only file in which we do changes?
      4. Can anyone suggest a checklist to manage massive project in RH8.
      5. I tried to import master page from parent project to child project but content get duplicated.
      Thanks and Regards,
      Rahul
        • 1. Re: Changing header and footer in massive projects
          RoboColum(n) Level 5
          Hi Rahul and welcome to the RH community.
          Can you give us a little more detail? Where are the headers and footers? Is it only the master project that needs updating? Is the master page only in the master project or in all projects?
          • Read the RoboColum(n) for a tips, tricks and musings on the Technical Communication Suite products.
          • Follow the RoboColum(n) on Twitter
          • 2. Re: Changing header and footer in massive projects
            Rahul karn1 Level 1
            Header is on the top of the page and footer contain copyright notice in
            which i have to make changes which is at the bottom of the page.Master page
            is only in the master project. in Master project all the 249 projects are
            merged.
            Thanks and Regards,
            Rahul
            • 3. Re: Changing header and footer in massive projects
              OK but what I really need to know is exactly what needs to be changed. It definitely sounds like the footer needs changing but maybe the header doesn't. What I also don't know is whether the header and footer are part of the master page.
              • 4. Re: Changing header and footer in massive projects
                Rahul karn1 Level 1
                Thanks for the effort and time you are giving me.I do some R&D main problem
                is:
                Yes,footer is the part of Master page of parent project.
                Master page is applied only in Parent project not in merged (Child) project.
                Now i have to change footer in all the projects including Master and child.
                If i change in the parent project, will it be reflected in child project? or
                i will have to go one by one in all the project>change footer and then
                replace with the new updated project.
                Or is there any other way out?
                Br,
                Rahul
                • 5. Re: Changing header and footer in massive projects
                  You are confusing me a bit whe you say you want to "change footer in all the projects including Master and child". You also say that the footer is inside the master page which is only in the master project. If the footer that requires changing is only in the master project's master page, all you'd have to do is amend the footer in the master project's master page and recompile the master project. You won't have to touch the other child projects at all.
                  • 6. Re: Changing header and footer in massive projects
                    Rahul karn1 Level 1
                    - Footer is used in all the projects including child and parents
                       - Problem is master page is used only in parent project but footer is
                       used in all the pages of parent and child projects.
                       - I have to change the footer in the pages of parent and child projects.
                    I hope i cleared my problem.
                    To be more precised, how to change the footers in parent and merged project
                    If   master page is not applied.
                    Br,
                    Rahul
                    • 7. Re: Changing header and footer in massive projects
                      In that case you'll have to change the footer in all the child projects, compile them, change the master page in the master project and recompile that. Provided you have your merged TOC setup correctly, all the changes that were made to your child projects will be automatically picked up in the master when you compile.
                      • 8. Re: Changing header and footer in massive projects
                        Rahul karn1 Level 1
                        Thanks!!!
                        My new problem is that, now i find that in the parent project the applied
                        style sheet is different from the child project. As stated earlier in the
                        child project master page is not applied but style sheet is there.
                        In this case should i change the style sheet of master page,change the style
                        sheet of parent project or change the style sheet of child project and then
                        apply master page?
                        Style sheet of parent project is standard, which i want to consistent
                        through out in my project.
                        Br,
                        Rahul
                        • 9. Re: Changing header and footer in massive projects
                          This sounds like a bit of a mess. For consistency you want to have your style sheet and arguably your master page applied across all of your projects. Personally I would identify the master page and style sheet you wantand associate these with each other (by adding the style sheet inside the master page). Then I'd import that master page into each and every project and apply it to the topics as required. By importing the master page, the associated style sheet is also imported.
                          Of course all of this should be taken with a large pinch of salt as it all depends on what you are trying to achieve. If we want all your topics to look alike, the above approach is the way to go. Trouble is, it is not clear from your posts that this is what you are trying to do.
                          • 10. Re: Changing header and footer in massive projects
                            Unless the child projects are used standalone, you only need the CSS applied in the parent project. If any child project will be used as a standalone project, then it will use whatever is applied in the child, but not otherwise.
                            @petergrainge
                            • 11. Re: Changing header and footer in massive projects
                              Rahul karn1 Level 1
                              Exactly this is what i am trying to do,but when i apply master page in the
                              project,text gets repeted as shown below:
                                ©ABC2009. All rights reserved. Any reproduction or unauthorized use of
                              this material is expressly prohibited by law. Violators will be prosecuted
                              to the maximum extent possible.
                              © ABC2010. All rights reserved. Any reproduction or unauthorized use of
                              Changed footer appear in the desired style (Second paragraph)  but the text
                              of the old footer remain (first paragraph).
                              How to fix it?
                              Thanks again for taking pain to help me.
                              Br,
                              Rahul
                              • 12. Re: Changing header and footer in massive projects
                                It is difficult to see what is happening without seeing your project. Could you take a copy of your project, delete all but one topic, zip it up and send it to me. You'll find my contact details here. I may not be able to respond straight away though but promise to look at it later today.
                                • 13. Re: Changing header and footer in massive projects
                                  Rahul karn1 Level 1
                                  I am able to fix this problem.Now when i am trying to generate CHM from
                                  Robohelp in couple of project fetal error is displayed from Microsoft HTML
                                  complier.So how to fix this?
                                  Br,Rahul
                                  • 14. Re: Changing header and footer in massive projects
                                    Hi there
                                    If your CHM is failing a compile you will want to examine the output report to see what message is being posted. It may provide a clue. Assuming that fails for some reason, follow the steps below.
                                    Perhaps the Single Source Layout is corrupt. To  rule that out, create a new Single Source Layout and try again. If that fails...
                                    Odds are it's a single topic somewhere. The trick then becomes how to easily find the topic. So copy your project and delete half the topics. Compile. Does it work now? If so, the suspect topic is among the remaining half. Rinse and repeat as needed until you determine where the issue is.
                                    Cheers... Rick
                                    Helpful and Handy Links
                                    RoboHelp Wish Form/Bug Reporting Form
                                    Begin learning RoboHelp HTML 7 or 8 within the day - $24.95!
                                    Adobe Certified RoboHelp HTML Training
                                    SorcerStone Blog
                                    RoboHelp eBooks
                                    • 15. Re: Changing header and footer in massive projects
                                      Rahul karn1 Level 1
                                      Third option works for me.
                                      I find the topic whose degine view is not open is creating problem.Kindly
                                      find a attached image.
                                      In few case Project gets complied but left out the the page which degin view
                                      is not opening.I noticed if a project is big and 4-5 page is not opening
                                      then in that project HTML compiler show fatel; error.
                                      What to do in this case?
