5 Replies Latest reply on Mar 29, 2010 2:44 AM by Roy Marshall
    [JS][CS3] Getting Page Number
    Roy Marshall Level 1
      Hi.
      I need to find the page number of the page containing a frame.
      Normally I would use "myFrame.parent.name" to find the page number. However, I cannot use this method on an inline graphic.  What I get returned is the story, which has no page number.  I have used various ways, such as:
      myFrame.parent.insertionPoints[0].parent
      but nothing returns the page number.  I have looked at all the properties of the frame, and cannot find a property I can manipulate to extract the page number.
      Is this possible? Should I give up now?
      Cheers
      Roy
        • 1. Re: [JS][CS3] Getting Page Number
          கற்பனை (Imagine) Level 3
          Use the Below code,
          myFrame.parent.insertionPoints[0].parentTextFrames[0].parent.name
          Regards,
          Imagine.
          • 2. Re: [JS][CS3] Getting Page Number
            John Hawkinson Level 5
            Or simply myFrame.parent.parentTextFrames[0].parent.name.
            At least for me, the parent of an anchored object is a Character, which has a parentTextFrame that has a parent Page.
            • 3. Re: [JS][CS3] Getting Page Number
              Kasyan Servetsky Level 5
              Here is a function written by Dave Saunders:
              var myObj = app.selection[0];
              $.write("The selected object is on page " + findPage(myObj).name + "\n") ;
              function findPage(theObj) {
                  var thePage = theObj;
                  if (thePage.hasOwnProperty("baseline")) {
                    thePage = thePage.parentTextFrames[0];
                  while (thePage.constructor.name != "Page") {
                    var whatIsIt = thePage.constructor.name;
                    switch (whatIsIt) {
                      case "Story" :
                        thePage = thePage.textFrames[-1].parent;
                        break;
                      case  "Character" :
                        break;
                      case "Cell" :
                        try {
                          thePage = thePage.insertionPoints[0].parentTextFrames[0];
                          break;
                        } catch (e) {
                          // must be overset, so ignore
                          return null;
                      case "Application" :
                        // must be off page, so ignore
                        return null;
                    thePage = thePage.parent;
                  return thePage
              • 4. Re: [JS][CS3] Getting Page Number
                Another function by Marc Autret
                // by Marc Autret
                TextFrame.prototype.getPage = function()
                // Returns the containing Page of this TextFrame
                var p = this.parent,
                     pc;
                while( pc=p.constructor )
                     if( pc == Page )
                          return p;
                     if( pc == Spread || pc == MasterSpread )
                          throw Error("The textframe is placed on a spread!");
                     if( 'parentTextFrames' in p && !(p=p.parentTextFrames[0]) )
                          throw Error("The textframe's container overflows!");
                     p=p.parent;
                // Sample code (assuming a text frame is selected)
                var tf = app.selection[0],
                     pg;
                try {
                     pg = tf.getPage();
                     alert( "Page: " + pg.name + " Side: " + pg.side);
                catch(e)
                     alert( e );
                • 5. Re: [JS][CS3] Getting Page Number
                  Wow, thanks all.  The first answer is what I have used, although will concider stripping it back as the second.  I am not experienced enough too understand all that Daves script is doing, but will look at it for helpful tips.
                  Thanks all again
                  Roy
