3 Replies Latest reply on Mar 31, 2010 10:03 AM by Flex harUI
    Big bytesize of compiled SWF file from CSS by Flex 4 compiler
    JabbyPandaUA Level 3
      Hi all,
      I use the simplest CSS file as example:
      * CSS file
      @namespace s "library://ns.adobe.com/flex/spark";
      @namespace mx "library://ns.adobe.com/flex/mx";
      mx|Button {    font-size : 24; }
      When I compile the simplest CSS file into SWF using "compc" compile, Flex 4 SDK and framework linkage option "Use SDK default (runtime shared library)", the resulting size of SWF file is around 45Kb.
      When I compile the simplest CSS file into SWF using "compc" compile, Flex 4 SDK and framework linkage option "merged in code", the resulting size of SWF file is around 390Kb.
      Is that expected?
      In Flex 3 SDK triggering "framework linkage" type did not result in bloating of compiled CSS files in its size.
