Revision: 15087
Revision: 15087
Author: deeptika@adobe.com
Date: 2010-03-29 00:19:07 -0700 (Mon, 29 Mar 2010)
Log Message:
Merging revision 14933 from 4.x branch
Drag proxy should be stored always irrespective of whether drag is started in root application or not. However proxy is stored in the automation manager of the root app and root will return the proxy when it is asked for.
Fix: Earlier we were storing the proxy only if the application that initiated the application is root. Removed that check now.
QE notes:
Doc notes:
Bugs: FLEXENT-1244 (Main app loads sub app1 in same app domain which loads sub app2 in different app domain drag and drop of list from sub app1 to sub app2 does not get replayed)
Reviewer: Rani
Tests run: checkintests
Is noteworthy for integration:
Ticket Links:
http://bugs.adobe.com/jira/browse/FLEXENT-1244
Modified Paths:
flex/sdk/trunk/frameworks/projects/automation/src/mx/automation/delegates/DragManagerAutomationImpl.as
Property Changed:
flex/sdk/trunk/
