0 Replies Latest reply on Mar 29, 2010 5:07 AM by Thorgil
    problem with spry html dataset and XML in dreamweaver cs4
    Thorgil
      I have 2 problems with spry in Dreamwdeaver cs4. I hope someone can help me.
      I used spry xml databases before in CS3 without any problems, but now I wanted to try the new feature of the html-database linked dataset.
      I made an html-page with a simple database-table (ID: databank).
      I tried to add a spry interactive dataset on an other page, which didn't seem very complicated. I made a new interactive page based on this database but I always get several errors when I try to check out the result in live view or in firefox.
      I get the following errors in live view:
      failed to add 'spryregion1' as a 'dataSet observer!'
      failed to add 'spryregion2' as a 'dataSet observer!'
      Spry.Data.updateRegion(spryregion1) caught an exception: Type error:
      Value undefined (result of expression ds.getLoadDataRequestIsPe
      nding) is not object.
      Spry.Data.updateRegion(spryregion2) caught an exception: Type error:
      In firefox the errormessages are a bit different:
      Here's the file in which the dataset is used.
      http://users.ugent.be/~apeleman/html-gegevensset.html
      Here you can see the file with the database:
      http://users.ugent.be/~apeleman/databank-appels-tabel.html
      I did follow the instructions of the adobe tutorial, and I even tried it with their own database, but still nothing works. Not even when I put all the files on the external server.
      Can anyone tell me what I'm doing wrong?
      Also, in CS3 I could easily use foto's in my xml-database (I just had to mark them as images when creating the dataset), and use them in the interactive database on the other page. But now, in CS4, when I create a new interactive page based on that same database, the xml-dataset doesn't show the images anymore, it just shows the image-datalink: {fotos}, unless I change the code myself and put the image-datalink  {fotos} in between image-tags (<img src="{fotos}" >. This isn't very practical. Is there another way of inserting foto's in the interactive page?
      The pages I made in CS3 are working perfectly.
      Thanks for any help
