0 Replies Latest reply on Mar 29, 2010 9:22 AM by Paul Reilly
    [svn:fx-trunk] 15108: * Merged the fix for SDK-24472 from the sherlock sandbox to trunk.
    Paul Reilly
      Revision: 15108
      Revision: 15108
      Author:   preilly@adobe.com
      Date:     2010-03-29 09:22:20 -0700 (Mon, 29 Mar 2010)
      Log Message:
      • Merged the fix for SDK-24472 from the sherlock sandbox to trunk.
        This includes revisions 14005 and 14621.
      QE notes:
      Doc notes:
      Bugs: SDK-24472
      Reviewer: Tom H., Pete F.
      Tests run: passed full cyclone in sherlock and checkintests in trunk
      Is noteworthy for integration: yes, should reduce memory use in FB.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24472
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerSwcContext.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/io/InMemoryFile.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/io/VirtualZipFile.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/MovieTranscoder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/Swc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcCache.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcDirectoryArchive.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcDynamicArchive.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcGroup.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcLazyReadArchive.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcLibrary.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcScript.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
      Property Changed:
          flex/sdk/trunk/
