1 Reply Latest reply on Mar 29, 2010 3:11 PM by garynng
    Drop Down menus don't work
    garynng Level 1
      site of test page:  www.localwally.com/comic-con.html and www.localwally.com/hotels-northcounty.html
      On Dreamweaver I built the drop down menus on the navigation in "behaviors" and when I test the page it works as planned.  However, I just uploaded two pages to test the code and the drop down menus don't work on either page.
      Here is the code.  I know it might appear to be a bit clumsy since I moved the links around but again it works when you test it "offline" but does not work now that it is online.
      Appreciate your help - I am hoping to go "live" in a week and this is a major stumbling block.
      Gary
      <div id="menu_bar">
          <ul>
          <li></li>
            <li><a href="index.html" name="link6" id="link6" onmouseover="MM_showMenu(window.mm_menu_0302081412_0,0,30,null,'link6')" onmouseout="MM_startTimeout();">HOME</a></li>
            <li><a href="#" name="link14" id="link15" onmouseover="MM_showMenu(window.mm_menu_0807121340_0,0,30,null,'link14')" onmouseout="MM_startTimeout();">Hotels</a></li>
            <li><a href="#" name="link16" id="link2" onmouseover="MM_showMenu(window.mm_menu_0807122254_0,0,30,null,'link16')" onmouseout="MM_startTimeout();">Attractions </a></li>
            <li><a href="#" name="link17" id="link4" onmouseover="MM_showMenu(window.mm_menu_0813071050_0,0,30,null,'link17')" onmouseout="MM_startTimeout();">Good Eats  </a></li>
            <li><a href="agenda.html" name="link3" id="link7" onmouseover="MM_showMenu(window.mm_menu_0813072003_0,0,30,null,'link3')" onmouseout="MM_startTimeout();">Agendas</a></li>
            <li><a href="budget-san-diego.html" name="link5" id="link9" onmouseover="MM_showMenu(window.mm_menu_0822091617_0,0,30,null,'link5')" onmouseout="MM_startTimeout();">On a Budget </a></li>
            <li><a href="faqs.html" name="link12" id="link11" onmouseover="MM_showMenu(window.mm_menu_0822091743_0,0,30,null,'link12')" onmouseout="MM_startTimeout();">FAQs </a></li>
            <li><a href="http://localwally.proboards.com/index.cgi?" name="link18" id="link10" onmouseover="MM_showMenu(window.mm_menu_0822091908_0,0,30,null,'link18')" onmouseout="MM_startTimeout();">MessageBoard </a></li>
            <li><a href="http://twitter.com/localwally" name="link8" id="link13" onmouseover="MM_showMenu(window.mm_menu_0822092027_0,0,30,null,'link8')" onmouseout="MM_startTimeout();">Best of SD Awards  </a></li>
          </ul>
