1 Reply Latest reply on Jun 30, 2011 2:54 PM by tse020673
    DAT Backups
    dyanez@CGI Level 1
      All,
      Im running Adobe Central Pro 5.5, when the application I'm using sends that DAT file to the data folder I see it for an instance and then it disappears, which is fine, I get the output on the printer. The problem I have is its not creating a backup of the DAT file in the backup folder.
      I have modified the jfserver.ini to have the path of the backup folder, but I'm still not getting a backup of the DAT file, is there another location or setting that I have to change to have a bakcup of the DAT file?
      Any help or suggetison would be helpful.
        • 1. Re: DAT Backups
          tse020673 Level 1
          You have to restart Central Server if you changed the jfserver.ini.  If you haven't done it already, give it a shot.  Also, check the jfmerge.ini file just in case there is a setting about backing up the fiel when Cental is done with it.
