3 Replies Latest reply on May 7, 2010 5:32 AM by jiggy1965
    default fps
    jiggy1965 Level 1
      In Flash 8 / cs3 the dimensions, background color and fpt always remained the same upon opening a new flash document.
      In cs4 too, except for the framerate. When I open a new flash document that always becomes the fps used in the latest used flash document. So when I start a document and change the default 24 to 30 fps, close the document and start a new one, the fps is still 30? Why doesn't it stay the default 24?
        • 1. Re: default fps
          :::@::: Level 1
          Mysterious are the ways of Flash CS4 ...
          And can you even imagine there are people who still use MX and 5?
          Emil Georgiev - Flash and Web Design
          • 2. Re: default fps
            jiggy1965 Level 1
            #$@#%.... apparently, this is normal in cs4 according to the help files:
            'When you change the frame rate, the new frame rate becomes the default for new documents.'
            This is indeed weird. Remember this window where you can change the stage size, background color AND fps? Which has a 'Make Default' button? So what's the point of that now, since the fps is the only setting that doesn't stay default? Don't know why adobe did change this, but I could do without it...
            • 3. Re: default fps
              jiggy1965 Level 1
              Also I've found out that when you change the ftp in the timeline window, it turns back into the default fps when opening a new document.
              When you change the fps in the property inspector window, it stays that change fps when opening a new document.
              A bit weird, but at least I can change the fps now without turning it into the new default fps: by changing it in the timeline window.
