1 Reply Latest reply on Mar 30, 2010 5:54 AM by carstephun
    implementing Dirty Flag for a generated Model (Flex 4)
    carstephun
      Hi there,
      I try to implement a dirty flag for a model generated by a Data Binding Wizard. I tried several ways but always failed to get it work properly bounded to the 'enabled' property of a button. Is there a "best approach" to implement this in a by Flex 4 generated model?
      I have all the Form elements bound to the model's properties and defined fx:Bindings on the model's property as well to get the changes back to the model as well.
      -> I tried to listen to the properyChange event on the Super model but I always returned true for the Dirty flag and couldn't set it to false when I loaded the model into a Form.
      -> I tried to implement a similar approach like below, instead of doing a normal 'getter' function on the isDirty flag I bounded it to the propertyChange event, it failed exactly the same way as above
      I did used my own solution earlier like this:
      [RemoteClass(alias="VODictionaryEntry")]
           [Bindable]
           public class VODictionaryEntry
                     private var _id:Number = 0;
                     private var _terminology:String;
                     private var _description:String;
                     private var _notes:String;
                     private var _insert_date:String;
                     private var _update_date:String;
                     private var _vendor_related:Boolean;
                     public var isDirty:Boolean = false;
                     public function get vendor_related():Boolean
                          return _vendor_related;
                     public function set vendor_related(value:Boolean):void
                          _vendor_related = value;
                          isDirty = true;
                     public function get update_date():String
                          return _update_date;
                     public function set update_date(value:String):void
                          _update_date = value;
                          isDirty = true;
                     public function get insert_date():String
                          return _insert_date;
                     public function set insert_date(value:String):void
                          _insert_date = value;
                          isDirty = true;
                     public function get notes():String
                          return _notes;
                     public function set notes(value:String):void
                          _notes = value;
                          isDirty = true;
                     public function get description():String
                          return _description;
                     public function set description(value:String):void
                          _description = value;
                          isDirty = true;
                     public function get terminology():String
                          return _terminology;
                     public function set terminology(value:String):void
                          _terminology = value;
                          isDirty = true;
                     public function get id():Number
                          return _id;
                     public function set id(value:Number):void
                          _id = value;
                          isDirty = true;
      this is a very simple solution but it worked like a charm. Can somebody suggest me something else, a better solution?
      thank you
      r. Sandor
      P.S.: I didn't include the validators to simplify the example.
        • 1. Re: implementing Dirty Flag for a generated Model (Flex 4)
          carstephun Level 1
          hi,
          meanwhile I come a little bit further if you implement the isDirty flag into your remote model and let generate ( to be included in the flex model as well) a model with Flex you can listen to the propertyChange event and do implement a correctly functioning bindable property.
          public function VOMessageEntry():void
               addEventListener( PropertyChangeEvent.PROPERTY_CHANGE, handlePropertyChange );
          private function handlePropertyChange( event:PropertyChangeEvent ):void
               if ( event.property != "isDirty" )
                    isDirty = true;
          this code must be inserted into the generated Object itself not in the _Super_objectname source code.
          I hope I could helped somebody with this solution.
          r. Sandor
