3 Replies Latest reply on Mar 31, 2010 1:03 PM by jrunrandy
    Adobe Community Help
    John Hall Level 4
      Frequently when I search a term in Flash Builder and it fires up Adobe Help locally (which is fine with me), I'm greeted with the following message inside the AIR app
      Access denied
      We're sorry, you are not allowed access to the service you requested.
      If you feel you should have access, please contact the appropriate authorities and give them your IP address: 72.200.120.xxx
      Thank you for your patience.
      Any suggestions? At first I thought it was server overload but it's been a few days now. (It has a full IP, just don't like broadcasting it).
        • 1. Re: Adobe Community Help
          Jason San Jose Adobe Employee
          Do you have other CS5 betas installed?
          Jason San Jose
          Software Engineer, Flash Builder
          • 2. Re: Adobe Community Help
            Niall O'Donovan Level 7
            We had a similar problem. From other posts: when FB4 installs it may not update the community help file. The current version is 3.1.0.440. I downloaded this manually from the Labs page and selected "open" as instructed.
            Got help form the Flex Doc Team.
            If I open the community help AIR app directly, I have to select Flex from the drop down next to the search field:
            But when I now go to help from within FB4 it opens OK (without the warning) directly into the Flex content.
            So check the version of community help that you have and possibly upgrade.
            Niall
            • 3. Re: Adobe Community Help
              jrunrandy Adobe Employee
              We have also identified an issue with Windows 7 64-bit in which a configuration file is installed in an incorrect location. If you are using this configuration, copy the folder:
              C:\Program Files(x86)\Common Files\Adobe\HelpCfg
              into
              C:\Program Files\Common Files\Adobe
              Then restart Community Help.
              then go to Edit > Preferences > Local Content and click Update for each of the Help packages.
              HTH,
              Randy Nielsen
              Flex Doc Manager
