4 Replies Latest reply on Sep 12, 2007 8:16 AM by Chunick
    Retaining formating of text when write new file with FILEIO
    wgb14 Level 1
      Hi all,
      I wonder if there is any way to retain the formating of the text when I write it in a new file using FILEIO. In particular I have the following text in a field member:
      test <background = L1_garaz/> (text in the tag has color and itsbold) test
      I use the following code to write the above text in a new filw using FILEIO:
      on mouseup
      annot = member("annotator").text
      path = the moviepath & "Annotated_text\"
      whichanno = baGetFilename( "Save", ""&path&"", "", "doc files|*.doc", 0, "Save doc file", 0, -2, 0 )
      myanott = new(xtra "FileIO")
      myanott.createfile(whichanno) --create
      myanott.openFile(whichanno,0)
      writeString(myanott,annot) --write the new string
      myanott.closeFile()
      myanott = VOID
      end
      the problme is that despite the type of file that i will choose to save it (.doc, txt , etc) it refuses to save the text with its initial formating (with the color, and bold words). Any idea how to solve this?
        • 1. Re: Retaining formating of text when write new file with FILEIO
          Level 7
          "wgb14" <webforumsuser@macromedia.com> wrote in message
          news:fc7nf2$av3$1@forums.macromedia.com...
          > Hi all,
          > write
          > a
          > field member:
          > test
          > FILEIO:
          > on mouseup
          > myanott.closeFile()
          > myanott = VOID
          > end
          > (with
          What file format do you use to save the text?
          Of course you need to use an appropriate file-format, or invent your own.
          Maybe try HTML or RTF.
          Richard.
          • 2. Re: Retaining formating of text when write new file with FILEIO
            McFazstp Level 1
            If you want the formatting try saving the rtf of the member
            annot = member( "annotator" ).rtf
            Save the file with rtf extension.
            • 3. Re: Retaining formating of text when write new file with FILEIO
              wgb14 Level 1
              Nop, its says property not found rtf. Then if will save as an rtf (without changing to proprty of the member("annotator") again it won't keep the formmat of the main text
              • 4. Re: Retaining formating of text when write new file with FILEIO
                Chunick Level 3
                Use a text member instead of a field member then you can access the formatting of the text thru .rtf property... then, save that info to a file:
                annot = member("annotator").rtf
                quote:
