3 Replies Latest reply on Mar 31, 2010 9:51 AM by bringrags
    Difficulty pulling metadata from video.
    WebAppEngineer
      I am working with the OSMFPlayer sample and I have tried two different ways to pulling the metadata from the video and both have failed.
      First I tried:
      mediaElement = createMediaElement(url);
      if (mediaElement)
          var loadTrait:LoadTrait = mediaElement.getTrait(MediaTraitType.LOAD) as LoadTrait;
          loadTrait.addEventListener(LoadEvent.LOAD_STATE_CHANGE, onLoadStateChange);
      private function onLoadStateChange(event:LoadEvent):void
          switch (event.loadState)
              case LoadState.READY:
                  var videoElement:VideoElement = VideoElement(element);
                  videoElement.client.addHandler(NetStreamCodes.ON_META_DATA, onMetadata);
                  break;
      Second I tried:
      private function setupMediaFactory():void
          factory = new DefaultMediaFactory();
          factory.addEventListener(MediaFactoryEvent.MEDIA_ELEMENT_CREATE,onMediaElementC reation);
      private function onMediaElementCreation(e:MediaFactoryEvent):void
          if (e.mediaElement is VideoElement)
              var videoElement:VideoElement = e.mediaElement as VideoElement;
      That am I doing wrong here?
        • 1. Re: Difficulty pulling metadata from video.
          bringrags Level 4
          The first approach should work (provided that you call loadTrait.load()).  The second approach will also only work if you load the VideoElement.
          • 2. Re: Difficulty pulling metadata from video.
            WebAppEngineer Level 1
            I have tryied adding loadTrait.load(); in severial places that seem to make sense to me and still the onLoadStateChange method never gets called.
            • 3. Re: Difficulty pulling metadata from video.
              bringrags Level 4
              Here's an example that worked for me.  Note that I'm listening for the MediaPlayerStateChange's READY event rather than a loadStateChangeEvent (although the latter should work equally well):
              public class HelloWorld extends Sprite
                      public function HelloWorld()
                          // Create the container class that displays the media.
                           var container:MediaContainer = new MediaContainer();
                          addChild(container);
                          // Create the resource to play.
                          var resource:URLResource = new URLResource("http://mediapm.edgesuite.net/strobe/content/test/AFaerysTale_sylviaApostol_640_500_short.f lv");
                          // Create the MediaElement and add it to our container class.
                          videoElement = new VideoElement(resource);
                          container.addMediaElement(videoElement);
                          // Set the MediaElement on a MediaPlayer.  Because autoPlay
                          // defaults to true, playback begins immediately.
                          mediaPlayer = new MediaPlayer();
                          mediaPlayer.addEventListener(MediaPlayerStateChangeEvent.MEDIA_PLAYER_STATE_CHANGE, onStateChange);
                          mediaPlayer.media = videoElement;
                      private function onStateChange(event:MediaPlayerStateChangeEvent):void
                          if (event.state == MediaPlayerState.READY)
                              videoElement.client.addHandler("onMetaData", onMetadata);
                      private function onMetadata(info:Object):void
                          for (var value:Object in info)
                              trace(value + " = " + info[value]);
                      private var mediaPlayer:MediaPlayer;
                      private var videoElement:VideoElement;
