0 Replies Latest reply on Mar 30, 2010 11:31 AM by Paul Reilly
    [svn:fx-trunk] 15145: * Revert revision 15108, because it broke two mustella tests.
    Paul Reilly Level 1
      Revision: 15145
      Revision: 15145
      Author:   preilly@adobe.com
      Date:     2010-03-30 11:31:46 -0700 (Tue, 30 Mar 2010)
      Log Message:
      • Revert revision 15108, because it broke two mustella tests.
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerSwcContext.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/io/InMemoryFile.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/io/VirtualZipFile.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/MovieTranscoder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/Swc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcCache.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcDirectoryArchive.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcDynamicArchive.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcGroup.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcLazyReadArchive.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcLibrary.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcScript.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
