2 Replies Latest reply on Mar 30, 2010 1:19 PM by skipisley
    HELP!
    skipisley
      I can't figure out two things and they are driving me batty.
      1)  My drop down menu us coming down BEHIND a Flash onject below it.  I know there is a wmode code I can insert that should take care of the problem, but I need the EXACT code and EXACTLY where to place it.
      2)  I created a mega drop down menu with SoThink software.  It shows up perfectly in the Preview mode, but when I upload it to the Web it is a mess.  I'm sure some files are in the wrong place and something is pointing to the wrong file, but I can't figure it out.
      Here is the url to the test page http://www.whatisthatsong.net/index4.html
      Thanks for the help, I know there are a lot of people here who know WAYYYYY more than me.
        • 1. Re: HELP!
          HELP! is not a meaningful subject.  Most people will skip over your qustion because you haven't provided a description of the problem in your subject line. Next time use a better subject like "Help with Flash and SoThink Menus."
          Flash always rises to the top.  If you are having competition problems from Flash objects, you should move it away from your menus.  WMODE will not solve this problem in all browsers.
          I don't use SoThink Menus so I can't help you with that.  You will probably get better answers from the Menu maker than you will here.
          Nancy O.
          Alt-Web Design & Publishing
          Web | Graphics | Print | Media  Specialists
          http://alt-web.com/
          http://twitter.com/altweb
          http://alt-web.blogspot.com
          • 2. Re: HELP!
            skipisley Level 1
            Sorry for the bad title description...very frustrated.  The wmode change does not work, already tried it, still searching for the fix.  If worse comes to worst I will move the Flash object, but I really wanted it where I have put it.
