3 Replies Latest reply on Apr 3, 2010 3:05 PM by Zabeth69
    Dreamweaver CS4 attempted to free unallocated memory bug
    nicoladie Level 1
      Dreamweaver CS4 Mac version 10.0.0.4117 has a fatal bug.  It is trying to free up unallocated memory.  Most likely, it is trying to free the pointer twice, which ended up attempting to free memory that does not belong to it.  This corrupts the system memory, and bring down Snow Leopard, causing the notorious freeze problem in Snow Leopard.
      See the system log, right after Dreamweaver crashed, it corrupted the system memory, causing Safari to freeze right after that:
      Mar 30 14:08:32  Dreamweaver[505]: Dreamweaver(505,0xa0aae4e0) malloc: *** error for object 0x2fac3a90: pointer being freed was not allocated\n*** set a breakpoint in malloc_error_break to debug
      Mar 30 14:08:32  [0x0-0x32032].com.adobe.dreamweaver-10.0[505]: Dreamweaver(505,0xa0aae4e0) malloc: *** error for object 0x2fac3a90: pointer being freed was not allocated
      Mar 30 14:08:32  [0x0-0x32032].com.adobe.dreamweaver-10.0[505]: *** set a breakpoint in malloc_error_break to debug
      Mar 30 14:10:23  Safari[216]: Periodic CFURLCache Insert stats (iters: 1107) - Tx time:0.285461, # of Inserts: 16, # of bytes written: 276255, Did shrink: NO, Size of cache-file: 181460992, Num of Failures: 0
      Here is the log that shows the repeated error:
      Mar 30 15:28:33  [0x0-0x47047].com.adobe.dreamweaver-10.0[887]: objc[887]: Class ApolloPasteboardSource is implemented in both /Applications/Adobe Dreamweaver CS4/Configuration/Flash Player/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLib and /Applications/Adobe Dreamweaver CS4/Adobe Dreamweaver CS4.app/Contents/Frameworks/AdobeOwl.framework/Resources/AuthPlayLib.bundle/Contents/MacO S/AuthPlayLib. One of the two will be used. Which one is undefined.
      Mar 30 15:28:34  /Library/Application Support/FLEXnet Publisher/Service/11.5.0/FNPLicensingService[891]: Started - This service performs licensing functions on behalf of FLEXnet enabled products.
      Mar 30 15:28:57  com.apple.WebKit.PluginAgent[782]: Debugger() was called!
      Mar 30 15:29:33: --- last message repeated 2 times ---
      Mar 30 15:29:33  [0x0-0x47047].com.adobe.dreamweaver-10.0[887]: Dreamweaver(887,0xa0aae4e0) malloc: *** error for object 0x333e5dc0: pointer being freed was not allocated
      Mar 30 15:29:33  [0x0-0x47047].com.adobe.dreamweaver-10.0[887]: *** set a breakpoint in malloc_error_break to debug
      Mar 30 15:29:33  Dreamweaver[887]: Dreamweaver(887,0xa0aae4e0) malloc: *** error for object 0x333e5dc0: pointer being freed was not allocated\n*** set a breakpoint in malloc_error_break to debug
      Mar 30 15:29:57  [0x0-0x49049].com.adobe.dreamweaver-10.0[912]: objc[912]: Class ApolloPasteboardSource is implemented in both /Applications/Adobe Dreamweaver CS4/Configuration/Flash Player/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLib and /Applications/Adobe Dreamweaver CS4/Adobe Dreamweaver CS4.app/Contents/Frameworks/AdobeOwl.framework/Resources/AuthPlayLib.bundle/Contents/MacO S/AuthPlayLib. One of the two will be used. Which one is undefined.
      Mar 30 15:29:58  /Library/Application Support/FLEXnet Publisher/Service/11.5.0/FNPLicensingService[916]: Started - This service performs licensing functions on behalf of FLEXnet enabled products.
      Mar 30 15:30:20  Dreamweaver[912]: Dreamweaver(912,0xa0aae4e0) malloc: *** error for object 0x32bb42f0: pointer being freed was not allocated\n*** set a breakpoint in malloc_error_break to debug
      Mar 30 15:30:20  [0x0-0x49049].com.adobe.dreamweaver-10.0[912]: Dreamweaver(912,0xa0aae4e0) malloc: *** error for object 0x32bb42f0: pointer being freed was not allocated
      Mar 30 15:30:20  [0x0-0x49049].com.adobe.dreamweaver-10.0[912]: *** set a breakpoint in malloc_error_break to debug
      Mar 30 15:30:37  [0x0-0x4a04a].com.adobe.dreamweaver-10.0[942]: objc[942]: Class ApolloPasteboardSource is implemented in both /Applications/Adobe Dreamweaver CS4/Configuration/Flash Player/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLib and /Applications/Adobe Dreamweaver CS4/Adobe Dreamweaver CS4.app/Contents/Frameworks/AdobeOwl.framework/Resources/AuthPlayLib.bundle/Contents/MacO S/AuthPlayLib. One of the two will be used. Which one is undefined.
      Mar 30 15:30:37  /Library/Application Support/FLEXnet Publisher/Service/11.5.0/FNPLicensingService[946]: Started - This service performs licensing functions on behalf of FLEXnet enabled products.
      Mar 30 15:34:58  osascript[1018]: Error loading /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types:  dlopen(/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types, 262): no suitable image found.  Did find:\n /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types: no matching architecture in universal wrapper
      Mar 30 15:35:03  com.apple.backupd-auto[1012]: Not starting scheduled Time Machine backup - time machine destination not resolvable.
      Mar 30 15:35:48  osascript[1033]: Error loading /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types:  dlopen(/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types, 262): no suitable image found.  Did find:\n /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types: no matching architecture in universal wrapper
      Mar 30 15:35:58  Dreamweaver[942]: Dreamweaver(942,0xa0aae4e0) malloc: *** error for object 0x3332c4b0: pointer being freed was not allocated\n*** set a breakpoint in malloc_error_break to debug
      Mar 30 15:35:58  [0x0-0x4a04a].com.adobe.dreamweaver-10.0[942]: Dreamweaver(942,0xa0aae4e0) malloc: *** error for object 0x3332c4b0: pointer being freed was not allocated
      Mar 30 15:35:58  [0x0-0x4a04a].com.adobe.dreamweaver-10.0[942]: *** set a breakpoint in malloc_error_break to debug
