1 Reply Latest reply on Mar 30, 2010 7:44 PM by Ned Murphy
    Time out function when no mouse clicks or mouse holds detected
    xcmuddman Level 1
      Hi All,
      Is there anything that i can add/remove to/from the following code to make  it not timeout while the mouse button is being held down too?
      i have tried to modify Harry's code with the following:
      import mx.utils.Delegate;
      btn1.onPress = function(){
          clearTimeout();
      btn2.onPress = function(){
              clearTimeout();
      btn1.onMouseUp = function(){
          clearTimeout(nTimeoutId);
          setUserActivityTimeout()
      btn2.onMouseUp = function(){
      btn1.onMouseDown = function(){
      btn2.onMouseDown = function(){
      function setUserActivityTimeout():Void
          nTimeoutId = setTimeout(Delegate.create(this, onUserInactivity), nTimeTolerance);
      function stopTimer():Void
      function onUserInactivity():Void
          delete_root.onMouseUp;
      gotoAndStop("exit_no");
      Ned - im not skilled in programming enough to follow through with your advice:
      "Look into disabling the timer until a mouse up event occurs."
      something like:
      if
      MouseEvent.press == true
      then
      Pat
        • 1. Re: Time out function when no mouse clicks or mouse holds detected
          If you don't want the setTimeout to be operating while the mouse is down, do not call the setUserActivityTimeout() function in your mouse down code.
          Your mouse up code already has what I suggested.
          To become skilled in programming you need to be able to realize what tools you have and how to use them.  That won't come from people handing you solutions unfortunately... you've gotta lose hair, sleep, and your marbles to earn that skill.
