4 Replies Latest reply on Apr 3, 2010 12:23 AM by Shongrunden
    FB4 - custom component problem
    HakkaMc
      I created new custom component:
      <s:NavigatorContent  xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:mx="library://ns.adobe.com/flex/mx"
      label="universal" width="503" height="570"
      <s:TextArea name="ta" x="10" y="11" editable="false" width="483" height="353"/>
      <s:TextArea name="textToSend" x="11" y="398" width="482" height="164" editable="true"/>
      <s:Button x="327" y="370" label="Send message" id="sendButton"/>
      </s:NavigatorContent>
      and added it into the main MXML file into element
      <mx:TabNavigator id="myTabNavigator" x="442" y="24" width="503" height="570">
      </mx:TabNavigator>
      via ActionScript:
      var tComponent:tabComponent = new tabComponent();
      tComponent.id = "chatWindow";
      myTabNavigator.addElement(tComponent);
      But now I want to access the button with id="sendButton" from script section in the main MXML. I tried something like
      this["sendButton"] or tComponent.sendButton
      but having no luck.
      Is there a way how to access the element packed in custom component? Simply...I need something like document.getElementById("sendButton") and then add a click event listener.
      Thanks...
        • 1. Re: FB4 - custom component problem
          Gregory Lafrance Level 6
          How about something like this:
          myTabNavigator.getChildAt(0).sendButton
          You may need to do a cast:
          tabComponent(myTabNavigator.getChildAt(0)).sendButton
          If this post answers your question or helps, please mark it as such.
          Greg Lafrance - Flex 2 and 3 ACE certified
          www.ChikaraDev.com
          • 2. Re: FB4 - custom component problem
            HakkaMc Level 1
            Thanks a lot!
            The first type of access you wrote is incorrect but the second works!
            Once again thanks a lot :-)
            • 3. Re: FB4 - custom component problem
              HakkaMc Level 1
              The access works only if the added tab is selected or was once selected. Otherwise it looks like the button does not exist.
              AS code:
              <component creation>
              <adding component>
              Alert.show(tabComponent(myTabNavigator.getChildAt(myTabNavigator.numChildren-1))["sendButt on"]==null?"yes\n":"no\n"); //shows no
              <adding component>
              Alert.show(tabComponent(myTabNavigator.getChildAt(myTabNavigator.numChildren-1))["sendButt on"]==null?"yes\n":"no\n"); //show yes
              But if I chose the second tab and do
              it shows "no".
              • 4. Re: FB4 - custom component problem
                Shongrunden Adobe Employee
                Set creationPolicy="immediate" on the TabNavigator.  This will mean the contents of each tab are created at startup rather than when the tab is first visited.
