0 Replies Latest reply on Mar 31, 2010 5:29 AM by yderidde
    [svn:cairngorm3:] 15157: Simplifying the design of the module lib by:
    yderidde
      Revision: 15157
      Revision: 15157
      Author:   yderidde@adobe.com
      Date:     2010-03-31 05:29:35 -0700 (Wed, 31 Mar 2010)
      Log Message:
      - Refactoring the existing mechanism to support the inter-communication between modules thru a unique identifier.
      - Ability to communicate between multiple instances of the same module.
      - Removed the LazyLoader which was a temporary workaround.
      - Adding a new Metadata which must be used within messages that are inter-communication API messages (to communicate between modules).
      - Adding a message pool which basically keep all messages that need to be redirected to a module which is not yet instantiated until the module is available and ready to accept the messages.
      - Redo from scratch the ModuleTest application to show the new behaviors.
      - Refactored the InSync sample to use the new Module lib.
      Modified Paths:
          cairngorm3/trunk/libraries/Module/.actionScriptProperties
          cairngorm3/trunk/libraries/Module/.flexLibProperties
          cairngorm3/trunk/libraries/Module/src/com/adobe/cairngorm/module/ModuleInfo.as
          cairngorm3/trunk/libraries/Module/src/com/adobe/cairngorm/module/ModuleMessageInterceptor .as
          cairngorm3/trunk/libraries/Module/src/com/adobe/cairngorm/module/ParsleyFlexModuleFactory .as
          cairngorm3/trunk/libraries/Module/src/com/adobe/cairngorm/module/ParsleyModuleDescriptor. as
          cairngorm3/trunk/libraries/Module/src/com/adobe/cairngorm/module/ParsleyModuleInfo.as
          cairngorm3/trunk/libraries/Module/src/com/adobe/cairngorm/module/ViewLoader.as
          cairngorm3/trunk/libraries/ModuleTest/.actionScriptProperties
          cairngorm3/trunk/libraries/ModuleTest/.flexProperties
          cairngorm3/trunk/libraries/ModuleTest/src/example/MyViewLoader.mxml
          cairngorm3/trunk/samples/insync/insync-modularExtended-api/.actionScriptProperties
          cairngorm3/trunk/samples/insync/insync-modularExtended-api/.flexLibProperties
          cairngorm3/trunk/samples/insync/insync-modularExtended-api/src/insync/messaging/ComposeMe ssageEvent.as
          cairngorm3/trunk/samples/insync/insync-modularExtended-contacts/src/insync/contacts/prese ntation/ContactFormPM.as
          cairngorm3/trunk/samples/insync/insync-modularExtended-messaging/src/ComposeMessageModule .mxml
          cairngorm3/trunk/samples/insync/insync-modularExtended-messaging/src/ComposeMessageModule Rig.mxml
          cairngorm3/trunk/samples/insync/insync-modularExtended-messaging/src/insync/messaging/pre sentation/ComposeMessagePM.as
          cairngorm3/trunk/samples/insync/insync-modularExtended-shell/src/InsyncModularExtendedShe ll.mxml
          cairngorm3/trunk/samples/insync/insync-modularExtended-shell/src/insync/InsyncContext.mxm l
          cairngorm3/trunk/samples/insync/insync-modularExtended-shell/src/insync/presentation/Cont entViewStack.mxml
      Added Paths:
          cairngorm3/trunk/libraries/Module/src/com/adobe/cairngorm/CairngormModuleLib.as
          cairngorm3/trunk/libraries/Module/src/com/adobe/cairngorm/module/IParsleyModule.as
          cairngorm3/trunk/libraries/Module/src/com/adobe/cairngorm/module/ModuleIdMetadata.as
          cairngorm3/trunk/libraries/Module/src/com/adobe/cairngorm/module/ModuleMessageDispatcher. as
          cairngorm3/trunk/libraries/Module/src/com/adobe/cairngorm/module/ParsleyModuleReadyMessag e.as
          cairngorm3/trunk/libraries/ModuleTest/src/CairngormModuleLibSample.mxml
          cairngorm3/trunk/libraries/ModuleTest/src/CairngormModuleLibSampleContext.mxml
          cairngorm3/trunk/libraries/ModuleTest/src/example/ModulePod.mxml
          cairngorm3/trunk/libraries/ModuleTest/src/example/api/
          cairngorm3/trunk/libraries/ModuleTest/src/example/api/PingMessage.as
          cairngorm3/trunk/libraries/ModuleTest/src/example/moduleA/
          cairngorm3/trunk/libraries/ModuleTest/src/example/moduleA/ModuleA.mxml
          cairngorm3/trunk/libraries/ModuleTest/src/example/moduleA/ModuleAContext.mxml
          cairngorm3/trunk/libraries/ModuleTest/src/example/moduleA/ModuleAPM.as
          cairngorm3/trunk/libraries/ModuleTest/src/example/moduleB/
          cairngorm3/trunk/libraries/ModuleTest/src/example/moduleB/ModuleB.mxml
          cairngorm3/trunk/libraries/ModuleTest/src/example/moduleB/ModuleBContext.mxml
          cairngorm3/trunk/libraries/ModuleTest/src/example/moduleB/ModuleBPM.as
          cairngorm3/trunk/samples/insync/insync-modularExtended-api/src/insync/application/
          cairngorm3/trunk/samples/insync/insync-modularExtended-api/src/insync/application/Content Destination.as
      Removed Paths:
          cairngorm3/trunk/libraries/Module/src/com/adobe/cairngorm/module/LazyLoader.as
          cairngorm3/trunk/libraries/Module/src/com/adobe/cairngorm/module/ModuleDescriptor.as
          cairngorm3/trunk/libraries/Module/src/com/adobe/cairngorm/module/StyledModuleDescriptor.a s
          cairngorm3/trunk/libraries/Module/src/com/adobe/cairngorm/module/StyledModuleInfo.as
          cairngorm3/trunk/libraries/ModuleTest/src/CairngormModules.mxml
          cairngorm3/trunk/libraries/ModuleTest/src/CairngormModules2.mxml
          cairngorm3/trunk/libraries/ModuleTest/src/example/ExampleContext.mxml
          cairngorm3/trunk/libraries/ModuleTest/src/example/ModuleA.mxml
          cairngorm3/trunk/libraries/ModuleTest/src/example/ModuleB.mxml
          cairngorm3/trunk/libraries/ModuleTest/src/example/parsley/
          cairngorm3/trunk/samples/insync/insync-modularExtended-shell/src/insync/application/Conte ntDestination.as
