1. Re: Brush outline disappears
Davidle18 May 8, 2010 2:33 PM (in response to Bent Nielsen)I get the same thing in PSE8. For no apparent reason, the 'brush'
(the circle) suddenly disappears and I can't do any cloning, brushing etc. No
t only does the visible circle disappear, the function doesn't work either. I had to reboot the computer to fix it
. I had this same problem with Photoshop 7 - it is obviously an onging problem and it should have been fixed by Adobe by now.
2. Re: Brush outline disappears
Bent Nielsen May 9, 2010 3:10 AM (in response to Davidle18)I find that the problem often is due to a slightly stuck key like spacebar or return key, so try hitting them a few times. It's easier than rebbot;-)
3. Re: Brush outline disappears
TomWard888 Sep 15, 2010 7:47 AM (in response to Bent Nielsen)I ran into the same issue. realized my caps lock was on. Turned that off and the outline reappeared.
Hope that helps
4. Re: Brush outline disappears
Davidle18 Sep 15, 2010 7:58 AM (in response to TomWard888)Gosh - it's ages since I posted that problem! I've not had it recently, but
will remember that tip should it occur again
