2 Replies Latest reply on Mar 31, 2010 10:21 AM by giant frog
    cannot set the properties of an itemrenderer in sdk 4
    giant frog
      I have a project working in sdk 3 that creates an item renderer for a grid, and passes the field index to the renderer. In sdk 4, the
      property is null. Is this a bug? (code truncated)
      <?xml version="1.0"?>
      <mx:HBox xmlns:mx="http://www.adobe.com/2006/mxml" horizontalScrollPolicy="off" verticalScrollPolicy="off" horizontalGap="5" paddingLeft="6" implements="mx.core.IFactory">
          <mx:Script>
              <![CDATA[
                  [Bindable] public var fieldIndex:int = -1;
                  public function newInstance():*
                      return new statusItem();
                  override public function set data(value:Object):void {
                      super.data = value;
                      var status:String = "";
                      var statusImg:String = "";
                      if (value != null && value.length > 0 && fieldIndex > -1)   {
                          status = value[fieldIndex];
                          if (status != null && status.length > 0) {
                              switch(status.toLowerCase()) {
                                  case "open" : img.source = Icon1;
                                              break;
                                  case "closed" : img.source = Icon2;
                                      break;
                                  default : img.source = Icon9;
                                      break;
                      else {
                          img.source = errorIcon;
          </mx:Script>
          <mx:Image id="img" source="{blankIcon}" verticalAlign="middle" width="10" height="10" />
          <mx:Label id="lbl" text="{data[fieldIndex]}" />
      </mx:HBox>
      parent code
      var sRenderer:ClassFactory = new ClassFactory(statusItem);
                                                  sRenderer.properties = { fieldIndex: x };
                                                  dgc.itemRenderer = sRenderer;
      It is simple code that works in version 3, but not in version 4.
      thanks,
      Jon
