0 Replies Latest reply on Mar 31, 2010 6:41 AM by Andre Mattos
    Application hangs on filterFunction
    Andre Mattos
      Hello all,
      I'll try to describe the problem before posting the code, which is a little bit long.
      I have a search popup with a dataGrid, who's dataProvider is connected to an ArrayCollection object, which is fed by a HTTPService that is reloaded every 5 minutes.
      When I launch the application for the first time and the popup is called, the application hangs. If I refresh the browser and repeat the exact same steps, the application works perfectly.
      The size of the data loaded into the ArrayCollection does not influence the results; I have tried with one record and the full size, 3Mb, and the problem keeps going on.
      Has someone gone through this issue before ? Any suggestions ?
      Thanks in advance.
      André
