4 Replies Latest reply on Apr 1, 2010 10:07 AM by JockMahon
    populating a Tree
    JockMahon
      Iv a tree that i want to populate with a  result set from the server.
      This rs will have rows where each row will be catergoised , so current , sent , failed etc
      I need to populate the tree so that it will look some thing like
      current
           Order 1
           Order 2
      Sent
           Sent 1
           Sent 2
      Failed
           Failed 1
           Failed 2
      how can i do this
        • 1. Re: populating a Tree
          Skiadzo Level 1
          this is a way to do it. It uses an xml entity that you construct and control.
          I use something similar in an app on which I am working. In that application, I put the mx:Tree at the first element of mx:HDividedBox container, followed by a mx:VBox containing a mx:ViewStack. If all of your content looks the same, you can skip the mx:ViewStack.
          <mx:XMLList id="treeData">
          <node label='top'>
          <node label='current'
          <!-- add current content so that has the following form -->
               <node label='Order 1'/>
               <node label='Order 2'/>
          </node>
          <node label='Sent'
          <!-- add sent content -->
          </node>
          <node label='Failed'>
          <!-- add failed content -->
          </node>
          </node>
          </mx:XMLList>
          <mx:Tree id="myTree" showRoot="false" dataProvider="{treeData}" change="treeChanged(event)" />
          <mx:Script><![CDATA[
          // Event handler for the Tree control change event.
          private function treeChanged(event:Event):void
               var selectedNode:XML =Tree(event.target).selectedItem as XML;
               var label:String = selectedNode.@label; // or add your own attribute
               // do something
          ]]></mx:Script>
          Hope this helps.
          • 2. Re: populating a Tree
            JockMahon Level 1
            how do u build up a dynamic xml, can u do
            <node  label='top'>
            for( var i = 0 ; i < 10 ; i++)
                  <node label='Order i'/>
            </node>
            • 3. Re: populating a Tree
              Skiadzo Level 1
              Hmm. Probably not.
              Consider...
              create the variable treeDate via
              <mx:XMLLIST id='treeData'/>
              then in your code:
              var top:XML = <node label='Top'/>
              treeData.appendChild(top);
              var currentBranch:XML = <node label='current'/>
              top.appendChild(currentBranch);
              var leafNode:XML;
              var label:String;
              //loop
              leafNode = <node label={label}/>
              currentBranch.appendChild(leafNode);
              //end loop
              Now, this is a code sketch, so salt & pepper to taste.
              • 4. Re: populating a Tree
                JockMahon Level 1
                thanks iv have got this working by doing the following
                            var xm:XML = <Orders></Orders>;
                            var ordersArray:Object = new Object();
                            ordersArray["1"] = "<node label='Current' templateID='1'>";
                            ordersArray["3"] = "<node label='Sent' templateID='3'>";
                            ordersArray["5"] = "<node label='Failed' templateID='5'>";
                         for(var i:uint = 0 ; i < event.result.length ; i++)
                       ordersArray[String( event.result.getItemAt(i)["ORDER_STATUS_ID"] ) ] += '<node label="' + event.result.getItemAt(i)["TEMPLATE_NAME"] + '" ';
                       ordersArray[String( event.result.getItemAt(i)["ORDER_STATUS_ID"] ) ] += 'templateID="' + event.result.getItemAt(i)["ORDER_TEMPLATE_ID"]+ '"/>';
                            ordersArray["1"] += "</node>";
                            ordersArray["3"] += "</node>";
                            ordersArray["5"] += "</node>";
                            for(var j:String in ordersArray )
                                var xmlList:XMLList = XMLList(ordersArray[String(j)]);
                                xm.appendChild(xmlList);
