5 Replies Latest reply on Mar 31, 2010 1:44 PM by Peter deHaan
    from XML to mx.control.List
    JPAntona Level 1
      var x:XML;
      x = <data><employees><employee label="A, Jean-Paul" data="23511"/>
                <employee label="B, John" data="12345"/>
                <employee label="C, John" data="23456"/>
                <employee label="D, Kelly" data="34567"/>
                 <employee label="E, Martin" data="45678"/>
                <employee label="F, Stacey" data="56789"/>
                <employee label="G, Tracy" data="67890"/>
      </employees></data>;
        • 1. Re: from XML to mx.control.List
          Peter deHaan Level 4
          Not exactly sure what your question is, but you can display that XML structure in an mx:List control using the following code:
          function(){return A.apply(null,[this].concat($A(arguments)))}
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
              <mx:Script>
                  <![CDATA[
                      private function init():void {
                          var theXML:XML;
                          theXML = <data><employees><employee label="A, Jean-Paul" data="23511"/>
                          lst.dataProvider = theXML..employee;
              </mx:Script>
              <mx:List id="lst" labelField="@label" width="100" initialize="init();" />
          </mx:Application>
          Peter
          • 2. Re: from XML to mx.control.List
            JPAntona Level 1
            You were able to interpret my question from that broken post (I accidentally hit post before I was ready). You deserve credit for that.
            I applied your post to my code (see below) put it still ain't working. This is Flex 3 in Flex Builder.
            I am having difficulty getting XML  attribute values to display as  items in a mx.controls.List. The  context for the code below is a  ActionScript class definition.
            public function getSuggestions(evt:KeyboardEvent):void {
            var x:XML;
                 //Alert.show(x.toString());
                                //var lxml:XMLListCollection = new XMLListCollection(x.employees);
                                //theList.labelFunction=xmlLabelParser;
                                //theList.labelField="@label";
                                //theList.dataProvider = lxml;
                                theList.dataProvider = x.employee;
                                theList.height = listHeight;
                                Alert.show("" + theList.rowCount); // this always print "5" no matter what
                                this.height = theText.height;
                                theList.includeInLayout = true;
                                theList.visible = true
            public function xmlLabelParser(item:Object):String {
                           Alert.show(xmlLabelParser: + item.toString());
                           var lxmx:XML = new XML(item);
                        return item.employees.employee.label;
            Here is the MXML:
            <mx:TextInput id="givenInput" x="1" y="1"
                           editable="true" enabled="true" width="100%" />
                      <mx:List height="100" enabled="true" x="0"
                            width="100%" visible="false"
                           includeInLayout="false" labelFunction="{xmlLabelParser}" />
            What  seems  to be happening is that the Collection is holdint just one object  -  the entire XML object. From the Alert.show in the label function I  can  see that the item is the entire XML contents. Even so, I can't seem  to  get any data out of it.
            • 3. Re: from XML to mx.control.List
              OK, doing a bit of guessing here, but in your getSuggestions() method, change this...:
              ... to this:
              theList.dataProvider = x.employees.employee;
              Next guess would be to change your xmlLabelParser() method from this...:
              ... to this:
              return lxmx.@label;
              Peter
              • 4. Re: from XML to mx.control.List
                JPAntona Level 1
                OK. It is working now. The key was this:
                • 5. Re: from XML to mx.control.List
                      <mx:Script>
                          <![CDATA[
                              public function getSuggestions():void {
                                  var x:XML;
                                  x = <data>
                                          <employees>
                                          </employees>
                                      </data>;
                              public function xmlLabelParser(item:XML):String {
                                  return item.@label;
                      </mx:Script>
                      <mx:List id="theList" width="200" labelFunction="xmlLabelParser" initialize="getSuggestions();" />
                  </mx:Application>
                  Peter
