This content has been marked as final.
Show 2 replies
1. Re: Is it possible to decrease l/r margins?
pguerett Apr 1, 2010 6:05 AM (in response to Bill95722)I think you are referrinng to the content area. This is the area where objects are placed. This content area is defined on the master page. By default there is a .5 in margin around the whole page. In the hierarchy view, expanf the MasterPages node, then the Page1 node. There will be an obejct called contentarea. Choose that object. You should see it highlighted in the drawinng area. Now you can resize the content area to fit your need....or you can go to the layout tab and set the width and height fo the contentarea if you prefer that way.
Paul
2. Re: Is it possible to decrease l/r margins?
Bill95722 Oct 31, 2010 9:10 AM (in response to pguerett)This was a printer setup problem
