10 Replies Latest reply on Apr 13, 2010 2:36 AM by Krish.praveen
    TextLayoutFramework - Japanese Text
    Krish.praveen Level 1
      Hi all,
      I found some strange things to happen to TLF used in my application.
      The original text looks like this.
      ニコン液晶露光装置 「FX-75S」「FX-85S」
      But when it moves to the TLF editor, it looks like this.
      As you can see the the special characters moved to boxes..
      Can any one help me to find the solution ASAP.
      Thanks in Advance
      Krishna
        • 1. Re: TextLayoutFramework - Japanese Text
          Flex harUI Adobe Employee
          Make sure the font you are using supports those characters.
          • 2. Re: TextLayoutFramework - Japanese Text
            Thanks for your reply.
            I do check for the same regarding the font used.
            I also found one strange thing over here in the text is one of the character that gots displayed but other cannt.
            like this letter in the context
            「FX-75S」- Its the original text.
            Its in text layout editor
            My concern is, how it displays the first character but not the last one. Any comments on this?
            thanks in advance.
            Krishna
            • 3. Re: TextLayoutFramework - Japanese Text
              Post a simple test case.
              • 4. Re: TextLayoutFramework - Japanese Text
                Thanks for the response.
                Here is the case :
                I am using GRID, to show this text. Where i use two different controls in item editor and renderer.
                In item renderer it shows this text.
                But when i tried to edit, it moves to TextLayout Editor. It displays as in this format.
                Hope this will help you out to get into the scenario. If any further needs, let me know.
                Krishna
                • 5. Re: TextLayoutFramework - Japanese Text
                  That's not a test case.  Let's see about 20 lines of MXML that I can copy
                  and paste and run.
                  • 6. Re: TextLayoutFramework - Japanese Text
                    This is the sample code, what i am trying out.
                    <mx:WindowedApplication
                    xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" xmlns:local="*"
                    creationComplete="init()" horizontalScrollPolicy="
                    off" viewSourceURL="srcview/index.html">
                    <mx:Script>
                    <![CDATA[
                    import flashx.textLayout.events.ScrollEvent;
                    import flashx.textLayout.events.FlowOperationEvent;
                    import flashx.textLayout.events.CompositionCompletionEvent;
                    import mx.controls.Image;
                    import flashx.textLayout.events.FlowElementMouseEvent;
                    import flashx.textLayout.elements.FlowElement;
                    import flashx.textLayout.elements.FlowLeafElement;
                    import flashx.textLayout.edit.ElementRange;
                    import flashx.textLayout.edit.TextRange;
                    import flashx.textLayout.events.SelectionEvent;
                    import mx.controls.CheckBox;
                    import mx.collections.ArrayCollection;
                    import flashx.textLayout.formats.Direction;
                    import flashx.textLayout.elements.InlineGraphicElement;
                    import flashx.textLayout.events.StatusChangeEvent;
                    import air.update.events.StatusUpdateEvent;
                    import flashx.textLayout.formats.ContainerFormat;
                    import flashx.textLayout.formats.ICharacterFormat;
                    import flashx.textLayout.formats.CharacterFormat;
                    import mx.events.SliderEvent;
                    import flashx.textLayout.edit.UndoManager;
                    import flashx.textLayout.edit.EditManager;
                    import flashx.textLayout.container.DisplayObjectContainerController;
                    import flashx.textLayout.conversion.TextFilter;
                    import flashx.textLayout.elements.TextFlow;
                    import flash.text.TextField;
                    import mx.core.UIComponent;
                    import mx.collections.XMLListCollection;
                    import mx.managers.DragManager;
                    import mx.core.DragSource;
                    import mx.events.DragEvent;
                    import flash.events.MouseEvent;
                    Bindable] static public var imgClass:Class;
                    Bindable] private var _textContainer:Sprite = null;
                    public var image:InlineGraphicElement;
                    private
                    static const textInput:XML =
                    <TextFlow xmlns="http://ns.adobe.com/textLayout/2008">
                    株式会社ニコン(社長:苅谷道郎)は、第7~8世代のプレートサイズに対応した液晶露光装置「FX-75S」「FX-85S」新型2機種の販売を開始いたします。
                    液晶テレビは数量ベースで、世界市場の過半数を超え、急速な普及が進んでいます。また、そのフラットパネル(省スペース)という特徴とともに、従来のブラウン管テレビでは実現できなかった画面 サイズの大型化もさらに進化しております。一方、デジタルサイネージに代表されるインフォメーションディスプレイも近年大きな注目を浴びつつあります。
                    </TextFlow>;
                    private
                    var _textFlow:TextFlow;
                    private function init():void
                    _textContainer =
                    new Sprite();
                    canvas.rawChildren.addChild(_textContainer);
                    var cf:CharacterFormat = new CharacterFormat();
                    _textFlow = TextFilter.importToFlow(textInput, TextFilter.TEXT_LAYOUT_FORMAT);
                    _textFlow.flowComposer.addController(
                    new DisplayObjectContainerController(_textContainer, canvas.width-40, canvas.height));
                    _textFlow.interactionManager = new EditManager(new UndoManager());
                    _textFlow.interactionManager.setSelection(0,0);
                    _textFlow.flowComposer.updateAllContainers();
                    </mx:Script>
                    <mx:Canvas id="canvas" width="450" height="150" backgroundColor="#ffffff" verticalScrollPolicy="auto/>
                    </mx:WindowedApplication>
                    Hope this will help it out.
                    Krishna
                    • 7. Re: TextLayoutFramework - Japanese Text
                      dave cragg Level 2
                      I couldn't get your script to compile. (Which SDK version are you using?)
                      However, I saw the same problem when setting the textFlow of a Spark TextArea to the Japanese text in your example.
                      1.  If I set no fontFamily on the TextArea, it displays with the boxes as you describe.
                      2.  (On a Mac) if I set the fontFamily to "Osaka", it displays correctly without the boxes.
                      But I don't think you should have to set the fontFamily specifically for this to work. You should just have a default Japanese font on your system somewhere. The fact that the text displays correctly in the Flash Builder script editor suggests this is a bug.
                      While playing with this, I noticed I couldn't enter Japanese text in the TextArea. When I switch the input mode to Japanese, nothing happens. I'm pretty sure during the beta test, I was able to enter Japanese (although it required the non-inline entry window).
                      Is handling Japanese generally a problem with Flex/Flash? I haven't had to work with Japanese text much in Flex, but I have some projects coming up where this will be important.
                      • 8. Re: TextLayoutFramework - Japanese Text
                        I use SDK 3.3
                        Font Installed for japanese is : Arial Unicode MS (arialuni.ttf).
                        Krishna
                        • 9. Re: TextLayoutFramework - Japanese Text
                          If you are using embedded fonts, all embedded fonts for a component instance
                          must be from the same SWF and you must use fontFamily to hint to the
                          component.  See the post on embedded fonts on my blog
                          Alex Harui
                          Flex SDK Team
                          Adobe System, Inc.
                          http://blogs.adobe.com/aharui
                          • 10. Re: TextLayoutFramework - Japanese Text
                            My issue was different, can you help me to solve the same.
                            Krishna
