1 Reply Latest reply on Jun 17, 2011 11:36 AM by yiotix
    Flex 4 and Photoshop CS 5 Plugin
    Kauff2
      I am wondering if anyone else is having this problem.  I have created a Flex 4 application and placed it into the Plugins\Pannel directory of Photoshop CS5.  When I load the plugin and resize it, the plugin scales and does not resize as expected.  Is there something I am missing?  I have checked some plugins that I created with Flex 3 and they work well.  Also I have used blank Flex 4 applications and they also have the same problem where they scale and dont resize.
      Rob
        • 1. Re: Flex 4 and Photoshop CS 5 Plugin
          yiotix
          I have been experiencing the same issue. I haven't figured out a clean solution to this yet, and as to why it doesn't resize flex 4 plugins properly but it does resize flex3 plugins..
          Just this morning I figured out a workaround. here is a snippet.
          <s:WindowedApplication
              width="100%" height="100%"
              resize="windowedapplication1_resizeHandler(event)"
          and the resize handler:
              <fx:Script>
                  <![CDATA[
                      import mx.events.ResizeEvent;
                      protected function windowedapplication1_resizeHandler(event:ResizeEvent):void
                          parent.parent.scaleX = 1;
                          parent.parent.scaleY = 1;
              </fx:Script>
          I looked into what the parent.parent is, and it seems that its a FlexLoader. There should be some way to keep the flexLoader from scaling.
          Let me know if you found out any other solution.
