9 Replies Latest reply on May 15, 2009 4:16 AM by Taff Payne
    calculate score
    iamalex
      Can someone pls help.
      Script suppose to write correct and incorrect answers and then display in summary, but not working.
      Below is main script and script for summary.
      main script:
      function QuizItem(question)
      this.question=question;
      this.answers=new Array();
      //reset stats
      this.numOfAnswers=0;
      this.correctAnswer=0;
      //returns question of this item
      this.getQuestion=function()
      return this.question;
      // add answer to multiple choice items
      this.addAnswer=function(answer, isCorrectAnswer)
      this.answers[this.numOfAnswers]=answer;
      if (isCorrectAnswer)
      this.correctAnswer=this.numOfAnswers;
      this.numOfAnswers++;
      // this function returns the n-th answer
      this.getAnswer=function(answerNumberToGet)
      return this.answers[answerNumberToGet];
      // returns index of corret answer
      this.getCorrectAnswerNumber=function()
      return this.correctAnswer;
      // checks if the passed number is the correct answer index
      this.checkAnswerNumber=function(userAnswerNumber)
      if (userAnswerNumber==this.getCorrectAnswerNumber())
      gotoAndPlay("Correct");
      //Correct_Incorrect.text = "Correct";
      else
      gotoAndPlay("Incorrect");
      //Correct_Incorrect.text = "Incorrect";
      this.getNumOfAnswers=function()
      return this.answers.length;
      //this function parses the XML data into our data structure
      function onQuizData(success)
      var quizNode=this.firstChild;
      var quizTitleNode=quizNode.firstChild;
      title=quizTitleNode.firstChild.nodeValue;
      var i=0;
      // <items> follows <title>
      var itemsNode=quizNode.childNodes[1];
      // go thru every item and convert it into our data structure
      while (itemsNode.childNodes )
      var itemNode=itemsNode.childNodes
      // <item> consists of <question> and one or more <answer>
      // <question> always comes before <answer>s
      // (Ie: <question> is the node 0 of <item>
      var questionNode=itemNode.childNodes[0];
      quizItems =new QuizItem(questionNode.firstChild.nodeValue);
      var a=1;
      //Go thru every answer and add to data structure
      // <answer> follows <question>
      var answerNode=itemNode.childNodes[a++];
      while (answerNode)
      var isCorrectAnswer=false;
      if (answerNode.attributes.correct=="y")
      isCorrectAnswer=true;
      quizItems
      .addAnswer(answerNode.firstChild.nodeValue, isCorrectAnswer);
      // goto the next <answer>
      i++;
      //decoding complete, start now
      gotoAndStop("Start");
      var quizItems=new Array();
      var myData=new XML();
      myData.ignoreWhite=true;
      myData.onLoad=onQuizData;
      myData.load("quiz.xml");
      stop(); //continue when xml is loaded
      summary script:
      userScore=(numOfQuestionsAnsweredCorrectly*100)/(numOfQuestionsAnsweredIncorrectly+numOfQu estionsAnsweredCorrectly);
      stop();
      thanks,
      alex
