6 Replies Latest reply on Apr 2, 2010 12:15 PM by Marcidus
    Memory leak with spark TextArea
    Marcidus
      i've noticed with the append method of a spark TA instance uses a large amount of memory, but oddly, only whilst text is present in the text area.
      for example if you append and then remove all text, the memory is restored, however if left alone, the textarea uses about 1 megabyte every 4-5 appends.
           private function append(type:String, text:String):void {
                  this._textArea.appendText(type + text + "\n");
      what would cause simple text to take up so much RAM?
      cheers
      flos
