2 Replies Latest reply on Apr 3, 2010 12:51 AM by Michel Bozgounov
    Help Creating Starburst With Randomized Rays
    noxbane
      Check out this background image below (or view larger size at this link:http://i3.campaignmonitor.com/themes/site_themes/default/img/bg_site-home.jpg) . I would like to know how they created the "randomized" effect of the rays behind the gray box.   I already know how to make your standard starburst using Abealls auto shape extension, but that creates uniform rays.  The rays of light in the below example are seemingly random.  I know this can be easily done in Photoshop using filters, but can it not be easily done in Fireworks?
        • 1. Re: Help Creating Starburst With Randomized Rays
          Michel Bozgounov Level 2
          Here's my try ( btw, welcome to the forums! ) and even if it is not random, it is close to the desired effect.
          http://www.optimiced.com/web/2010/starburst/starburst-fw.png
          Save the file to your computer and de-construct. I have added a Noise filter effect, a bit of Gaussian blur and there is a half-transparent rectangle on top of the rays, with gradient (rays use gradient, too).
          Now, I suppose you could combine two Sunrays autoshapes, slightly shift one of them, make both half-transparent, and apply a bit different effects to both. You could also create a complex vector mask on top of the sunrays, with a complex gradient with varaible areas of half-transparency, and this could help create this "random effect" that you are going after...
          http://www.optimiced.com/web/2010/starburst/starburst-fw-2.png
          http://www.optimiced.com/web/2010/starburst/starburst-fw-3.png
          I hope that some wiser than me Fireworks guru will be able to help you more...
          Message was edited by: Michel (two more variants added)
          • 2. Re: Help Creating Starburst With Randomized Rays
            Btw, all three variants posted here by me can be opened and edited further in Fireworks -- these are editable PNGs. Have fun!
