1 Reply Latest reply on Apr 6, 2010 6:21 AM by Catalin Anastasoaie
    Auto update using AIR 2.0
    Jayagopal Flex
      This is my code
      <mx:WindowedApplication
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" fontWeight="bold"
      textDecoration="
      underline" creationComplete="preCheckForUpdate()">
      <mx:Script>
      <![CDATA[
      import air.update.ApplicationUpdater;
      import flash.events.ErrorEvent;
      import flash.events.IOErrorEvent;
      import air.update.ApplicationUpdaterUI;
      import air.update.events.UpdateEvent;
      import mx.controls.Alert;
      private var appUpdater:ApplicationUpdater = new ApplicationUpdater();
      private var updateXMLURL:String = "http://localhost/AutoUpdate1/update.xml";
      // Pre-read the server-side XML file to look for <force>yes</force>
      private function preCheckForUpdate():void
      try
      var loader:URLLoader = new URLLoader();
      loader.addEventListener(Event.COMPLETE, checkForUpdate);
      loader.addEventListener(IOErrorEvent.IO_ERROR, onIOError);
      // Just in case we can't read the update.xml
      loader.load(
      new URLRequest(updateXMLURL));
      catch(e:Error)
      Alert.show(e.toString());
      private function checkForUpdate(event:Event):void
      try
      setApplicationVersion();
      // Find the current version so we can show it below
      var myXML:XML = new XML(event.target.data);
      namespace items = "http://ns.adobe.com/air/framework/update/description/2.0beta2";
      use namespace items;
      var forceUpdate:String = myXML.force;
      appUpdater.updateURL = updateXMLURL;
      // Server-side XML file describing update
      //appUpdater.isCheckForUpdateVisible = false; // We won't ask permission to check for an update
      // If <force>yes</force> was found above, turn off the download and install dialogs
      /* if(forceUpdate.toLowerCase() == "yes") {
      appUpdater.isDownloadUpdateVisible = false;
      appUpdater.isInstallUpdateVisible = false;
      appUpdater.addEventListener(UpdateEvent.INITIALIZED, onUpdate);
      // Once initialized, run onUpdate
      //appUpdater.addEventListener(ErrorEvent.ERROR, onError); // If something goes wrong, run onError
      appUpdater.initialize();
      // Initialize the update framework
      catch(e:Error)
      private function onError(event:ErrorEvent):void {
      Alert.show(event.toString());
      private function onIOError(event:IOErrorEvent):void
      trace("Error loading URL.");
      private function onUpdate(event:UpdateEvent):void
      try
      appUpdater.checkNow();
      // Go check for an update now
      catch(e:Error)
      // Find the current version for our Label below
      private function setApplicationVersion():void
      try
      var appXML:XML = NativeApplication.nativeApplication.applicationDescriptor;
      var ns:Namespace = appXML.namespace();
      ver.text =
      "Current version is " + appXML.ns::version;
      catch(e:Error)
      </mx:Script>
      <mx:WipeRight
      id="slowright" duration="1000"/>
      <mx:Label x="93" y="135" text="Welcome to Rapidcare" fontSize="36" fontFamily="Times New Roman" color="#3C0B1F"
      creationCompleteEffect="
      {slowright}" height="89"/>
      <mx:Label x="178" y="186" color="#F81908" fontSize="36" fontWeight="bold" textDecoration="normal" id="ver"/>
      <mx:Label x="93" y="279" text="Hai"/>
      </mx:WindowedApplication>
      IT throws an error in this appUpdater.checkNow();
      Error #2044: Unhandled updateError:. text=unknown update version
      Please any provide solution for this
      Regards,
      Jayagopal
