2 Replies Latest reply on Apr 4, 2010 7:29 AM by uygar_yuz
    Flex movieclip size problem
    uygar_yuz
      Hi guys,
      I have exported a swc movieclip for Flex and can see the animation play, no problem. But the problem is when I change the width and height properties of the movieclip, the animation size doesn't change, only the background size changes, but I want to change the size of the animating object. The code fragmet is as follows:
      var myMovieClip:MovieClip = new MyMovieClipClass();
      myMovieClip.width = someWidth;
      myMovieClip.height = someHeight;
      var buffer:BitmapData = new BitmapData(someWidth, someHeight, false, 0xFFFFFF);
      buffer.draw(myMovieClip);
      How can I change the size of the animation properly?
      Thanks in advance.
        • 1. Re: Flex movieclip size problem
          Flex harUI Adobe Employee
          If the animation is attached to the root instead of the movieclip you might
          have a problem like that.  It depends on why the animation does not respond
          to the parent size.
          • 2. Re: Flex movieclip size problem
            uygar_yuz Level 1
            Ok, as you said, when I created the animation movieclip inside another movieclip, which both can be seen in the library pane, the problem is solved. The hierarchy is as follows:
            rootMovieClip
                 --> animationMovieClip
                      --->animation (the actual timeline)
            and the usage is as follows:
            var rootMovieClip:MovieClip = new MyMovieClipClass();
            var childMovieClip:MovieClip = rootMovieClip.getChildAt(0);
            rootMovieClip.width = someWidth;
            rootMovieCip.height = someHeight;
            childMovieClip.scaleX = someScale;
            childMovieClip.scaleY = someScale;
            var buffer:BitmapData = new BitmapData(rootMovieClip.width, rootMovieClip.height, false, 0xFFFFFF);
            buffer.draw(rootMovieClip);
            Thanks a lot.
